06-09-2008, 06:27 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
Monarch LED Conversion
Hello All.
I have searched the forums, and looked at most of the sources recommend, but can’t seem to locate a LED upgrade/replacement for my Monarch square tail/back-up lights. Any suggestions?
Thanks in advance for any help.
Jeff & Cindy
06-09-2008, 07:10 PM
Vagabond
1973 31' Sovereign
Fort Meade Md. RV park slot 8!!
, Motorsports Photographer
Are yours like mine?? In the next week I will be upgrading to the new bezels so I can go led!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
06-09-2008, 07:13 PM
1975 23' Safari
1978 31' Excella 500
Franklin
, Indiana
Dimmer, was your 3rd brakelight standard issue, or did you add it on?
Dallas Peak, MD 'That 70's Guy!'
VAC Past President
WBCCI #8481
06-09-2008, 07:24 PM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
There are 2 options for those type taillights without any major rework. A 90 degree 1157 with 30 leds and a pcb with 24 or 36 leds on an 1156 base. I bought mine from superbrightleds.com. The pcb mounted leds (I went with the 36-led wide-angle option) are intended for internal boat/rv use. I'll post pics and a review when installed, this week I hope. The pcb unit will be tried on my back-up (1156) lights just for kicks, if it works I'll buy some more, otherwise it'll go in the bath-room where the 4 incandescent bulbs can dry your hair if there was a blower attached!!! BTW: Buy the red leds if they are going behind a red lens, that way 100% of the light will be visible or else if you go white only the 'red' portion of that light will actually get beyond the red 'filter'/lens!
06-09-2008, 07:30 PM
Vagabond
1973 31' Sovereign
You like that don't you!!!!! It had to be oem, do to the rivets on the sides. It also works as a turn signal. But its the only one I have ever seen. But they have a replacement part in the parts department at the Mother Ship JC. DIMMER
06-09-2008, 07:45 PM
1999 34' Excella
Joshua
History doesn't repeat itself, people do!
06-09-2008, 08:08 PM
1978 28' Ambassador
Morada
My Monarch LED 'conversion' was much easier than the one linked in the post above...take a look here:
http://www.airforums.com/forums/f173...0-s-42187.html
Go to a Trucker's supply that has LED stuff and check out their lights...you'll probably find something real close like I did.
Ray & Pat; Morada, CA
06-10-2008, 06:50 AM
Jay
, Oklahoma
I do like it. Thanks for all the great info. Your AS looks great, too!
Jeff & Cindy
06-10-2008, 07:00 AM
Jay
, Oklahoma
DIMMER,
Mine do look like yours. Why new bezels? Are there no direct replacement LED parts available?
Jeff & Cindy
06-10-2008, 07:16 AM
Vagabond
1973 31' Sovereign
When the polish and new clear coat was done. I had the new trim and badges added. So now I'm going to add the new bezels and led tail lights. That Is, If I can make them work!!! DIMMER
