Old 12-13-2023, 02:01 PM   #1
2016 19' Flying Cloud
Deerfield Beach , Florida
Marker Light Gasket Replacement
Trying to replace the marker light gaskets which have dried out and causing some leaking. Guidance would be appreciated. Do I need to cut and splice the wiring? How easy is it to remove the lens to access the frame of the light fixture? This is on a 2016 Flying Cloud 19CB Bambi. Thanks, Dominic
dominicjohn is offline   Reply With Quote
Old 12-14-2023, 03:57 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
When I got my 1994 Excella I replaced nearly all the marker lights and installed new gaskets that I cut myself on a LASER machine. They could also be cut by hand easily. Mine were all cut from 1/8" neoprene which very nicely conforms to the Airstream as well as to the back of the light.
I'd suggest you thoroughly examine your lights - if they are still the factory installed lights the plastic may be getting near the end of its life. Sun and age make the plastic more brittle and prone to cracking. The new lights are cheap enough to replace any suspect ones now while you have them off.
The lights which were replaced obviously had the new gaskets installed before I completed the wiring, but for the ones which I reused I simply cut a slit for the wiring to pass through on the side of the gasket which would point down. Have not had any sign of leaking since, even after driving through some heavy rain a few times. The neoprene squishes down/out a bit when compressed and seems to make a good seal.
I have the file for the marker lights in Corel Draw - if you need it just send me a PM.
Richard
11018
richard5933 is online now   Reply With Quote
Old 12-14-2023, 05:44 AM   #3
2014 27' FB International
Lewisville , Texas
Check out this posting
Lots of good info here
https://www.airforums.com/forums/f44...ht-244926.html
NO NOIZE is offline   Reply With Quote
Replace Incandescent Marker Lights with LED Marker Lights Fwrandall55 Lights - Interior & Exterior 1 08-11-2021 07:34 PM
Tail Light and Marker light lens 68 TWind General Repair Forum 0 06-26-2014 11:34 AM
Marker Light Gasket - where dufferin Lights - Interior & Exterior 9 05-24-2007 04:15 PM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
