Old 07-28-2018, 05:40 PM   #1
Ft. Myers , Florida
Lost running light wire
I have to confess-I am a newbie. I am restoring a 1971 Safari. The PO allowed the port rear marker light wire and back up wire to retreat into the hole in the hull. I can’t find it. Rather than take apart the entire interior, can anyone give me an assistance for an easy way to find those wires before they short out against the hull. I know they’re in there somewhere?
Seawway is offline   Reply With Quote
Old 07-28-2018, 07:32 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Get a length of mechanic's wire, bend a hook in the end of it, and stick it through the hole where the wire should go. Try fishing around, and see if you can snag the wire.
Old 07-28-2018, 08:14 PM   #3
Ft. Myers , Florida
Thanks I’ll try that this week.
Old 07-31-2018, 11:05 AM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
clothes hanger
I used a clothes hanger one time. (I did it too :-) Straightened it out and put a hook on the end. In the future, and for the benefit for anyone else who is reading this thread, I suggest use a pair of small vise grip pliers to hold the wire so it will not fall inside while to get the surface and the new light ready to install.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 07-31-2018, 11:44 AM   #5
PKI
PKI's Avatar
Walnut Creek , California
Harbor freight and other discount outlets sell inexpensive cameras with flexible fiber optic extensions that let you see inside walls. Good for a lot of DIY projects and inspections. The other tool is a flexible grabber. It is a tube with three spring claws that extend to grab something when you push on a button at the other end. Great for grabbing nuts and wires, too. Most auto parts stores have these.
The hole may be too small for all this, but maybe. A bit of tape might make the two tools an assembly. I think some cameras have an optional hook for just this purpose.
Good Luck. Pat
Old 07-31-2018, 07:00 PM   #6
Ft. Myers , Florida
Good Luck. Pat
This is really great advice for a rookie like me! I thought about trying to make the whole a little larger to accommodate a more sophisticated tools. Is that advisable? Thanks again for everything.
Old 07-31-2018, 07:02 PM   #7
Ft. Myers , Florida
Thanks for that suggestion. Is there a place inside whereI could unbutton some of the skin to peek in at that area? I thought pulling a couple rivets inside might be better than a bigger hole in the outside skin.
Old 07-31-2018, 08:26 PM   #8
DaveP's Avatar
2004 28' Classic
Monument , Colorado
No. You are pretty much stuck. Make the hole bigger and buy a camera off of Amazon then fish the wire out with a wire hook. That's what I did (successfully). Do not compound the problem...
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 08-01-2018, 05:11 AM   #9
Ft. Myers , Florida
Thank You again.
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 06:09 AM
Lost wire to running lights Steve & Susan 2002 - 2005 International 5 05-07-2012 08:22 AM
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Rear Running Light Wire snapped spat61 Airstream Motorhome Forums 0 06-12-2010 07:10 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
