Old 10-21-2024, 04:12 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
light above the door
i installed the light above our door
i use construction adhesive to mount it
and outdoor caulking to wrap around the edge and make it water proof
i wired the light to behind the radio as there is plenty of room and easy power
Name:	door light 2.jpg
ID:	448386   Click image for larger version
Name:	door light 1.jpg
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 10-21-2024, 04:59 PM   #2
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
Looks good. I don't recall, I think you posted in the past with questions about mounting this. Did it have a light before? Where did the switch go?
But what I really want to know though, is what direction the light points? Our 2023 GT has the same light and it points off to the left facing it. I'd think it should point straight.
I added this to our punch list when we took our trailer to JC for warranty work. The technician, instead of fixing it said it was "normal". I didn't get to ask what the deal was. I could take it apart and move it I suppose, but maybe there's some purpose pointing it off to the left.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 10-21-2024, 05:19 PM   #3
2024 28' Flying Cloud
Bartlett , Tennessee
How did you run the wire from above the door to behind the radio?
Bobbo and Lin
2024 F-350 Crewcab 4x4 gasser
2024 Flying Cloud 28RBTwin
Bobbo is offline   Reply With Quote
Old 10-21-2024, 05:54 PM   #4
waninae39's Avatar
NCR , Ontario
I added additional led to the stock led. It is much brighter than the stock light
Behind the metal part that is water proof on 3 sides, I drilled a 1/4 " hole to run the wires in through both walls. I used the roof tape to ensure no water ingress
I already installed a cable run above the door to run xm radio. The ant is above the bathroom and xm radio is close to the radio
I drilled a hole in the rear of the cable run track. One end is above the upper cabinet, the other end by the radio
Thus no wires are seen
I will take more photos with one at night and the inside
BTW, I had installed a similar light in my old sport 22fb
It was sold and I needed a similar soln for the fc 25fb
WBCCI# 21212
Old 10-22-2024, 12:29 PM   #5
waninae39's Avatar
NCR , Ontario
here are a few more pics when installed
the wire are all hided behind the radio
the cable from the light goes through the channel and up into the base of the cabinet close to the window 95% hidden
i'll do one more tonight when it gets dark
Name:	light switch.jpg
ID:	448401   Click image for larger version
Name:	channel above door.jpg
Name:	outside door light during the day.jpg
WBCCI# 21212
Old 10-22-2024, 12:34 PM   #6
JeffKim's Avatar
2021 16' Bambi
It does appear yours goes off to the left as well. Humm....
2017 Audi Q7 3.0T
WBCCI 6343
Old 10-22-2024, 05:38 PM   #7
waninae39's Avatar
NCR , Ontario
this is what it looks like when it gets dark
Name:	door lite at night-2.jpg
WBCCI# 21212
Old 10-22-2024, 06:34 PM   #8
1999 28' Excella
Lake Mary , Florida
It would be much easier to get a solar powered Mr Beams LED light and mount it above the door. Or, a rechargeable motion activated LED strip with magnets that would be removable for charging or when driving at interstate speeds, or during rainy weather.
suncoasteng is offline   Reply With Quote
Old 10-22-2024, 10:05 PM   #9
waninae39's Avatar
NCR , Ontario
magnets do not stick to aluminum
IMHO, taking things on and off just seems like another hassle
WBCCI# 21212
Old 10-27-2024, 10:30 AM   #10
2023 33' Classic
Chandler , Arizona
we have a 2023 classic 33 and the lights assy is fully illuminated, unless your model has partial illumination, which I doubt. I do know they are LED's. That is definitely a warranty repair item to have your dealer fix.
Saullman is offline   Reply With Quote
Old 10-27-2024, 03:40 PM   #11
2018 23' International
Germantown , New York
Oh, that light really works?!? The one on our 2018 never did. Too small of an issue to bring back to the dealer and when I looked at it, I saw I'd have to re-caulk everything. So it went to the bottom of the priority list. But maybe before the snow flies - you guys motivated me!
TBone55 is offline   Reply With Quote
Old 10-27-2024, 04:02 PM   #12
waninae39's Avatar
NCR , Ontario
if your light still has the old incandesce bulb, its best to remove it and place LED in it's place. it is very easy to do and many sources to get LED tape
DO NOT buy the cheap Chinese led as they will fail within 1 year
WBCCI# 21212
Old 10-27-2024, 06:14 PM   #13
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I replaced the incandescent bulb over the door on our 2007 Bambi with an LED bulb. Not great but better than the original.
then learned of the kit offered by LED4RV " Over the Door Spot light for Airstream ODoor56-2 SKU2885" and installed it. What a difference!
I like it so much I am replacing the LED bulb on our 2015 23FB with the kit.
check in out!
"Keep your eyes on the road
Your hand upon the wheel"
Steamy1 is offline   Reply With Quote
Drain lines above above generator on AI 3OnOurWay Sprinter and B-van Forum 12 08-08-2024 12:48 AM
adding a light above the AS22FB door waninae39 Lights - Interior & Exterior 4 05-12-2019 03:21 PM
Light above door m. Clarke All Argosy Trailers 6 07-03-2009 09:19 PM
Light cover above door - where do I get one? Miss Vicki Lights - Interior & Exterior 2 05-17-2009 07:34 PM
Light above entry door silver buffalo Airstream Motorhome Forums 3 05-06-2004 08:40 PM
