Old 03-05-2023, 09:51 AM   #1
carladonnell's Avatar
2023 20' Caravel
2023 Atlas
Carriere , Alaska
Left tail light
Running lights work on left side, but turn, stop, and hazard do not. What is the fix? Thanks in advance.
carladonnell is offline   Reply With Quote
Old 03-05-2023, 07:34 PM   #2
2004 22' International CCD
Beaumont , California
1. Possible burned-out bulb; replace.
2. Possible failed trailer plug; verify.
3. Possible towing vehicle failure; verify.
Ndcctrucks is offline   Reply With Quote
Old 03-05-2023, 08:01 PM   #3
2023 20' Caravel
2023 Atlas
Carriere , Alaska
Thanks- if the right side is working fine, then it has to be burned out bulbs… do you know how many bulbs are in each tail light unit?
Old 03-05-2023, 08:14 PM   #4
1988 32' Excella
Robbinsville , New Jersey
NO, since you don't give a hint of what year and model trailer you have.
Many older trailers had 2 bulbs per side, new trailers have LEDs.
Could also be a bad connection.
Old 03-05-2023, 08:54 PM   #5
2023 20' Caravel
2023 Atlas
Carriere , Alaska
Apologies… Flying Cloud 2010
Old 03-05-2023, 09:50 PM   #6
1988 32' Excella
Ok, I think that means LED lights like this, they start in 2010.
https://odmrv.com/catalog/index.php?...oducts_id=1746
I believe this would make a bulb less likely, since it would be 10 LEDs per fixture.
left tail light malfunction Jfed Lights - Interior & Exterior 8 09-28-2015 08:49 PM
Left turn and left brake lights not working Morgan guy Lights - Interior & Exterior 9 02-01-2015 08:08 AM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 12:34 PM
Airstream Left and Right tail lights eBay Watch Airstreams on eBay 0 08-14-2012 05:00 PM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 01:52 PM
