Old 10-23-2018, 05:33 PM   #1
westfield , Massachusetts
I'm wired!!
Years ago I turned in the over head reading light in my 79 32 ft sovereign ... and I lost lost the lighting in the front of the trailer ... including the galley!@, spit and and step light . Lighting remained in the rest of the trailer . At the time I checked all the fuses and tried following the schematics and cleaned all the wires in the overhead fan light ( where it seemed the wiring seemed to sllnrun to ) no luck . Went t plug in lighting. Just the other day the bathroom lights blew out when turned on . pump and fan still turn on ... odd as they share a switch panel . The bulbs are all good so I know it's a switchnirnwiringnissue. I replaced the univolt some time ago after the front end issue. I'm at a loss . Without fishing though the whole trailer wiring is there a common problem I'm missing? The right plug on the exterior plug is also out . ¯\_(ツ)_/¯
towmommy is offline   Reply With Quote
g f r & g f i problems.....for the well wired folks.. 2airishuman Electrical - Systems, Generators, Batteries & Solar 61 03-25-2008 10:23 AM
Pre Wired for Heat 68 Safari soldiermedic Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-21-2006 02:52 PM
Cross wired 64 trade wind advice, please! A-Merry-Can Electrical - Systems, Generators, Batteries & Solar 22 08-28-2006 10:54 AM
Urgent! Alternator/isolator wired incorrect! Howard Lefkowitz Mechanics Corner - Engines, Transmission & More... 11 01-10-2005 08:39 AM
Properly wired? Bob Boucneau Electrical - Systems, Generators, Batteries & Solar 3 07-22-2003 10:39 AM
