Originally Posted by jcazes
1. Can I just pull the existing switches out of the faceplate? I removed the entire assembly, but it's not clear if I should just apply force to pop out the switches, or if the rocker below is not actually suited for this job.
The switches have a small tab on the ends that engage the faceplate. Push in and the switch should pop out.
I too bought the lighted switches because it's too easy to leave the WH on and forget.
I have not installed these yet, but I was told there is a ground available in the assembly that controls the WH. (Seems like GMFL made a post to me.)
I downloaded these instructions if you haven't seen them.
https://cdn.shopify.com/s/files/1/00...f?v=1619830342
Another consideration, which wouldn't bother me is to realize that
IF you turn on the WH on electric, but have no electric power, the light will still illuminate via the
12v. even though the WH is not really on. DUH.
There is a fix for that involving a small circuit board you must add that senses 120 v. but I'm more concerned about leaving it on when I do have power.
