Old 02-21-2024, 07:05 PM   #1
Jum
1975 Argosy 26
Louisville , Kentucky
I went a bit overboard with the new porch light
We have had our '75 Argosy for ~3 weeks now and one thing that has bugged me is the porch light has/had a retrofit LED setup inside it that was angled wrong and not very bright from 2013 based on the label on the circuit board.
So, I ordered some square 3500K LED boards with 12v drivers on them and modeled/3d printed a housing for them to go in the stock location.
This is just a test fit tonight, but I'm pretty sure 3x boards is overboard for what it needs to do.
I'll either back off to 1 or 2 for the next test. I have a few more changes to make on the 3d print to angle it back toward the trailer a bit more and try to recess it even more. I may also get some elliptical flood lenses to spread the light to the sides.
Jum is offline   Reply With Quote
Old 02-22-2024, 12:11 AM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
Very nice! I sympathize about feeling it's a bit much. I had a just-barely-too-bright LED above the door when I had my Argosy, and I found myself turning it off a lot when I was sitting outside. I find barely-too-dim more satisfying, but I'm fairly light-sensitive and picky about that kind of thing. I have flashlights with dim settings for walking the dog in campgrounds, e.g.
Deeper in the recess will probably help a lot with scatter toward where campsite picnic tables are, etc. One nice thing about the Argosy light position is that it's generally out of your direct sight line, and snugging the light source back into that enclosure will enhance that, while still getting some indirect scatter off the painted surface.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
Old 02-22-2024, 07:18 AM   #3
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
I ordered a replacement LED from LED4RV that has three focused LEDs that fit in the over the door housing. It was very bright so I ordered a frosted lens and some Roccolux Congo Blue Theatrical gel and now I have plenty of blue light that does the job without annoying the neighbors. Links:
LED: https://led4rv.com/catalog/index.php...roducts_id=591
Frosted lens:https://led4rv.com/catalog/index.php...roducts_id=400
Congo Blue Gel (or pick any colour you like): https://www.amazon.com/gp/product/B000B75UHA/
Name:	Congo Blue - 1.jpg
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 03-31-2024, 10:49 AM   #4
Jum
1975 Argosy 26
I did back it off to 1 LED puck with an elliptical flood lens. So much better though there is some color shift due to the lens but it's not really an issue. I 3d printed multiple iterations to get the best angle/position to keep the light controlled. When the door is open, it lights the step and entry very well.
ID:	442338   Click image for larger version
Old 03-31-2024, 11:04 AM   #5
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I picked up a set of Monster Luminescence 12 bulb pak. They are dimmable and color changing. Looking forward to trying these out this week.
https://monsterilluminessence.com/sm...-string-light/
I will hang them off the awning.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
'Porch' Light Replacement Fixture with 1141 Bulb AirConditioner Electrical - Systems, Generators, Batteries & Solar 4 09-10-2015 11:56 PM
Porch light cleaning GlenCoombe Lights - Interior & Exterior 10 06-30-2013 02:16 PM
Porch light plug recepticle. FreshAir Lights - Interior & Exterior 33 04-27-2007 07:58 PM
Porch light only on Battery power???? campngirl Batteries, Univolts, Converters & Inverters 11 10-21-2006 06:55 AM
The $8 Porch Light Silverfly 1960 - 1964 Overlander 2 09-21-2004 06:25 PM
