Old 12-29-2009, 12:41 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Humphrey gaslights
I have always been fond of Humphery gaslights. Growing up in the early 1970s, a friend had a cabin on an island, and had several of them as the primary source of lighting, the possibilities of generators, batteries, and inverters not being what they are today.
I have one in my house, in a central location, because it provides safe, reliable, bright light in the event of a power failure. The only trouble I've ever had with it was a spider web that I had to remove. It's been there for ten years now.
When did Airstream stop installing these? Does anyone still use them in trailers? Why aren't these more popular for boondocking?
Old 12-29-2009, 12:51 PM   #2
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Because some folks are afraid of propane leaks and open flames maybe?
It's on my list of things to install into our rig.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 12-29-2009, 12:58 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have installed at least one in any trailer I ever owned. I consider the gas lite an essential, not only providing light and saving battery power, but also a good chill chaser on nippy evening. In addition it seems mantle life is a good indicator of how smooth things are on the road.An often broken mantle could indicate out of balance wheels, tire problems etc.
I suspect they may have been offered as an option at one time but the only trailer I have owned that had one when I bought it was a 54 Safari
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 12-29-2009, 01:14 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Looks like the last time they appear as an option is around 1976... at least in print..
Airstream, Inc :: Specs - 1970
Old 12-29-2009, 02:33 PM   #5
Baltimore , Maryland
I use mine all the time. The gas light is a great tool for long term boon dock camping. The only complaint I have is the mantle breaks every time I tow so we go through a number per season.
Old 12-29-2009, 03:01 PM   #6
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Russellville , earth
Definitely on my add list. Its a long, long list........
Rodney
Visit my photography and painting website
https://rooseveltfineart.com
Instagram is r.w.roosevelt
Boondocker is offline   Reply With Quote
Old 12-29-2009, 03:22 PM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
I have had mantles break within minutes of moving in some trailers. IN my 61 tradewind I have had them last as long as 10,000 miles. I bought the last load of mantles through Cabella's and think they are genuine Humphrey. Will look next time I am in the trailer
13 Ram 2500 TD
Old 12-29-2009, 03:40 PM   #8
The genuine Humphrey mantles are the best for sure. They do last the longest and the sock is very thick making for a more intense glow. I was given two at a rally and now use the coleman ones.
Old 12-29-2009, 06:34 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
AFAIK they no longer make the Humphery brand lights, but Mr Heater has a supply of very similar ones.
My AS does not have one...yet. But I have a couple of NOS units left over from somewhere that are going to get used for my install.
Aaron
WBCCI #XXXX AIR #2495
Old 12-29-2009, 06:58 PM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Humphrey was bought out by Paulin. You can by lights similar to the originals and they have parts also. Link to main page and parts page below...
Gas Lights by Paulin, Humphrey and Falks
propaneproducts.com: Gas Lights - Parts & Mantles
Old 12-29-2009, 07:21 PM   #11
I might know where a late 50's and an early 60's one is.....
Old 12-29-2009, 08:09 PM   #12
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Ok, Now I'm Curious
Where are the gas light usually mounted?
How are the propane lines run?
What kind of clearances must be maintained?
What kind of ventilation regimens must be observed?
And of course, post pictures!
Seriously. I have always heard about the gas lights in trailers, but have never actually seen one. I would appreciate pictures of installed gas lights and discussion of what those of you who added them did.
Vaughan
Old 12-29-2009, 08:31 PM   #13
San Angelo , Texas
Images: 37
On our Sovereign, the light would be mounted on the roadside partition, where the fridge is. The only pic I have is of a Cruisette, sans mantle or globe, courtesy of www.vintageairstream.com (not Greg Gibson's site).
Name:	1951 15' Cruisette_024.jpg
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 12-29-2009, 08:52 PM   #14
tallytwo1994's Avatar
tallahassee , Florida
Here's are photos, but someone else will have to answer your questions or maybe this website has the info.
Paulin Humphrey Gas Lights
http://www.gas-lights.com/pdf/paulin-installation.pdf
Carol
ID:	93150   Click image for larger version
tallytwo1994 is offline   Reply With Quote
Old 12-30-2009, 12:04 AM   #15
Here's my contribution. It was mounted on the end of the street-side overhead compartment, above the refer. The gas was tapped off of the branch of the gas line that goes to the refer with 1/8" copper. It came through the floor right next to the refer and ran up the wall to the overhead cabinet, alongside the refer shroud, then into the cabinet, and into the back of the light.
Rich the Viking
Name:	'64 SAFARI 039.jpg
VIKING is offline   Reply With Quote
Old 12-30-2009, 03:16 AM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
I have yet to find a Paulin version of the light for sale, only the Mr Heater ones...
Aaron
Old 12-30-2009, 03:19 AM   #17
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
I have only seen them mounted on the forward facing bulkhead of the fridge compartment.
On the 70's vintage the line was run in the fridge compartment, I believe it tees off the fridge LP line under the trailer.
IIRC clearances to the ceiling needs to be 12" or so, side clearances are similar.
Ventilation? crack a window.
Aaron
Old 12-30-2009, 04:13 AM   #18
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Aaron
Try here:
PAULIN OUTDOOR PRODUCTS - INDOOR HEATERS
they all look similar - the vintage 70's style had a little longer body that hung down behind the globe (have one I got on Ebay that needs repainted and installed).
Old 12-30-2009, 05:42 AM   #19
Lehman's the Amish super store has them.. Lamps & Lights*|*Gas Lighting*|*Gas Lights*|*Paulin/Humphrey Gas Light Parts - Lehmans.com
Old 12-30-2009, 06:04 AM   #20
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Looked at the Lehman site and also Cabella's where I bought my last batch of mantles. Price seemed high for the soft mantles. Could be more than 1 in a pack but did not say.
Here is another source, less than a buck a piece
Paulin, Humphrey, Falks Preformed - Tie Mantles
13 Ram 2500 TD
greg gibson, vintage-airstream.com
Humphrey Gas Mantles ColtSAA45 General Interior Topics 3 03-21-2004 02:05 PM
