Old 08-14-2022, 10:19 AM   #1
1988 34' Excella
Zepyr , Ontario
How to replace the spring on the exterior flood light?
Anyone know how to replace the spring at the bottom of the external flood light? Mine has corroded and it isn’t pushing up the connection to engage the bulb
I’m a 1988 excella 34’
Pics below:Click image for larger version
ID:	420946Click image for larger version
jeepinaldo is offline   Reply With Quote
Old 08-14-2022, 10:50 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
That would be a new fixture swap. I’m not sure you could replace the spring with any long term success.
https://highskyrvparts.com/search-ai...h-light-500092
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 08-14-2022, 11:08 AM   #3
Chelsea , Maine
Pull on it and stretch it a bit. Clean the contact surfaces. It’ll work until it fails again.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 08-14-2022, 11:09 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I'd agree that replacing the fixture is the easiest solution. When you get the new one, double check the gasket that goes between the lens and the fixture. I had these on my coach and they were problematic and frequently allowed water into the fixture causing corrosion like you have. In the end I cut a new gasket from neoprene to replace the paper or cork one they come with.
Richard
11018
richard5933 is offline   Reply With Quote
Wanting to replace the side and read rectangular flood lights with LED's KB6YAF Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 05-09-2022 09:19 AM
Argosy exterior Flood Light Gasket buffaloman Lights - Interior & Exterior 3 07-11-2011 07:41 PM
scare/flood light CampUnger Lights - Interior & Exterior 9 05-28-2011 09:31 PM
Exterior door, flood light airdreamers Lights - Interior & Exterior 2 12-24-2009 12:05 AM
Flood light lens melting nickcrowhurst Lights - Interior & Exterior 5 12-24-2003 09:38 AM
