Old 06-14-2024, 12:50 PM   #1
2018 16' Sport
Monterrey , Nuevo León, Mexico
How to connect stop lights and turn signals on a 2017 Toyota Hilux?
Hello everyone, I am Eduardo. I recently acquired a 2018 Airstream RB Sport Bambi, and I am very new to this.
have a problem since my towing truck is a 2017 Toyota Hilux and I had to install all the 7-pin wiring from scratch. However, I realized that the stop lights and turn signals share the same circuit, while my truck has two separate lights for each function. Therefore, only the turn signals work, but I don't have stop lights. Does anyone know how I can install or connect to have both lights working?
lalo1893 is offline   Reply With Quote
Old 06-14-2024, 01:15 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
RE: How to Connect Stop Lights and Turn Signals on 2017 Toyota Hilux?
Greetings Eduardo! Welcome to the Forums and the world of Airstream ownership!
You need something called a Tail Light Converter to combine the function of your tow vehicle's turn signal and brake lights. This link will take to one such example on the E-Trailer website. I do not know whether there may be a more economical source in Mexico.
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 06-14-2024, 08:14 PM   #3
2018 16' Sport
Thank you so much. It’s already work ��������
Brake lights, turn signals, reverse lights not working! HELP! blogworthy Argosy Motorhomes 6 04-16-2018 06:21 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Stop Sights, Turn Signals Shiny metal Lights - Interior & Exterior 5 09-14-2009 10:20 AM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
