Old 10-25-2021, 07:10 AM   #1
tkowalyk's Avatar
2013 27' FB Classic
Clermont , Florida
Images: 11
How do you remove the exterior LED marker lights?
I have a 2013 Classic.
I’ve noticed a gap where water could get in where the teardrop light touches the base.
How do you remove the lights?
I don’t want to break the light.
I plan on making a gasket or sealing.
Thanks!
tkowalyk is offline   Reply With Quote
Old 10-25-2021, 12:32 PM   #2
"Cloudsplitter"
That 'gap' is where you insert a properly sized screwdriver to remove the lens...very carefully.
It also allows for condensation evaporation, I wouldn't 'seal' it.
If you insist, just a dab of removable butyl caulk in the opening, but remember if yours are LED's=no heat to help evaporate the condensation, the reason all mine are still incandescent.
Replace Incandescent Marker Lights with LED Marker Lights Fwrandall55 Lights - Interior & Exterior 1 08-11-2021 08:34 PM
Upgrade to LED Brake/Marker Lights Advice? TOM CRUMP Lights - Interior & Exterior 9 11-09-2007 08:25 PM
LED Running/marker Lights-Teardrop BornToRock Electrical - Systems, Generators, Batteries & Solar 2 12-18-2006 01:46 PM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 10:54 PM
