Old 10-10-2023, 05:18 PM   #1
1973 Argosy 24
Memphis , Tennessee
Help
Iím having extreme difficulty figuring out the trailer lights to the truck. When I took the old plug off the trailer I noticed that the wires were hooked up differently. I am seeking info from anyone who might know the color code on the wires bc Iím trying to wire up a new end. I have a yellow which usually means left signal, green which usually means right signal, brown which usually means running lights, white that usually means ground, blue that usually means brakes, then the have a black n red wire. Anyway, I wire it up but nothing on the trailer is working except the bright side of the 1157 bulb which Iím assuming that is the turn signal n or brake light but it doesnít blink. Any help out there. Itís a 1973 24 ft argosy camper
J. Wessinger is offline   Reply With Quote
Old 10-10-2023, 07:38 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
The first thing I would do is make sure I have a good ground. I would use a pair of jumper cables from the trailer frame to the TV hitch.
CRH is offline   Reply With Quote
Old 10-10-2023, 08:03 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Attached you will see a diagram from the 1973 Airstream owner's manual showing how the lights are wired. I would expect an Argosy to be wired the same. Note that this wiring scheme does not match modern standards, hence the second diagram.
Good luck!
Name:	Airstream wiring (2020_01_22 20_33_51 UTC).JPG
ID:	437668   Click image for larger version
Name:	7 pin connector wiring (2020_01_22 20_33_51 UTC).JPG
Old 10-11-2023, 09:25 AM   #4
Belegedhel's Avatar
Houston , Texas
I got your PM--thought I would respond here. Attached is a blown-up version of the wiring diagram, that should be more readable.
It used to be possible to download vintage user's manuals from the Airstream.com website, usually by going to support and looking in the document archives. The user manual has a lot of information in it, but what you will probably really need is the Service Manual, which I have never seen as a free download. I bought one on ebay, and that might be the first place to look. There are several threads on these forums discussing various places to get the service and user manuals--just try searching for "service manual" and you should get several hits. Again, I don't know if there are separate manuals for the Argosy trailers, but they are generally the same as the Airstream branded models.
good luck!
Name:	1973 towing wiring.jpg
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
