Check for a loose ground
This happened to our Globetrotter as well. It would work intermittently which told me to look for a loose ground. Try removing the plastic lens and see if the ground wire is loose.
If I remember correctly I couldn’t get to the fastener (rivet?) but was able to push a washer as a shim under the housing to take up the gap and make contact. Good luck!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
