We have a 2013 International. The exterior bulb over the door has gone out. What is the best way to change it out? Do I have to remove the three screws and the entire cover? (this will require recaulking). Or, can I somehow remove just the plexiglass cover on the bottom to change the bulb?
2012 25' FB International
Trent Woods
, North Carolina
You can remove the plastic with careful prying, although I learned that after I removed the whole thing. Your problem may only be the ground wire, that was my issue. I crushed the rivet more and presto, it works again.
Larry
