Old 08-05-2010, 11:42 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Fiber Optics Bulb
Does anyone know where I can get one of the little fiberoptics pickup bulbs in the rear light?
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 08-07-2010, 01:57 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
One of mine is not working. Is that a bulb in the back? I don't understand how it works.
Click on the link to see a picture of the Sioux River falls near my home.
https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
Eastern South Dakota is very pretty with hills, rivers, and trees.
Splitrock is offline   Reply With Quote
Old 08-07-2010, 02:57 PM   #3
The tail light monitors are "fiber optic", which is plastic wire, if you wish.
Light travels thru plastic wire. If you cut the wire, you cannot easily splice it back to gether, so that it would continue to transmit light.
If one end of the optic wire is place against a light source, that will show at the other end of the optic wire.
The tail light monitor is nothing more than a optic wire placed behind a tail light bulb. The other end goes to the monitor indicator that's on the side of the trailer.
When the tail light bulb lights up, that light then shows at the other end.
Again, cutting a fiber optic wire is a bad thing, because the two cut ends must be put back together again,perfectly mated, which is near impossible,
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-07-2010, 05:59 PM   #4
Splitrock's Avatar
Originally Posted by Inland RV Center, In View Post
Again, cutting a fiber optic wire is a bad thing, because the two cut ends must be put back together again,perfectly mated, which is near impossible, Andy
Is there a way to check the continuity of the wire besides looking at the display (which doesn't work on one side)?
Gary
Old 08-07-2010, 06:13 PM   #5
Gary
Only with light.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-07-2010, 07:13 PM   #6
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
If I had one of the pickup bulbs I could go the the technology center (they have a class on fiber optics splicing/repair) and use their equipment to splice it back together. I took the class and I am sure they would not mind if I use their polisher/splicer.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 11-12-2010, 10:34 PM   #7
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Where is the fiber optic panel located again? I have a Sovereign where would it be in this trailer?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 11-12-2010, 10:43 PM   #8
x
XXXX , XXXX
It is located on the lower panel roadside towards the rear. look like this:
wasagachris is offline   Reply With Quote
Original Jack Fiber Gears niftypkg Jacks, Stabilizers, Lifting and Leveling 1 12-18-2007 02:25 PM
L.E.D.s meet fiber-optic telltales Excella CM Electrical - Systems, Generators, Batteries & Solar 0 09-29-2007 04:32 PM
Anyone heard of Fiber Floor? 78tradewind Floor Finishes 3 05-31-2007 11:33 AM
Fiber Optics...Coooool!!! Rivetedude On The Road... 14 11-17-2005 09:28 AM
