Old 06-05-2021, 05:13 AM   #1
2014 23' International
Saint Petersburg , Florida
Exterior LED Running Lights Flashing
Iím getting a rhythmic micro-flash on all my 2014 AS23D running lights when hooked up to TV (Curt Echo) The flash isnít full strength, itís more like a weak pulse firing 1 or 2 leds in each array. Itís like steady flash of an airplane NAV light. Not noticeable in bright sunlight. Definitely looks like an electrical leak. Only occurs when running lights off. The effect is kinda cool and goes away when lights come on. Any ideas? Is my AS haunted?
RMNummi is offline   Reply With Quote
Old 06-05-2021, 05:47 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
RMNummi,
Ghost Buster time.
Only happens when Echo is installed, correct. Is this a new install or an old install that just recently started flashing?
SWAG time. Does the Curt Echo send a brake circuit test signal periodically? Just a hello brakes are you still there and it uses this momentary electrical load test to verify brakes connected. If not found it signals check brake light. Is this test pulse the source and has somehow (SWAG) ghost connected and triggering pulsing.
Any recent repairs to 7 way cable or anything near it in AS?
Call Curt tech support, explain to them.
Early Sat AM ideas, not a diagnosis.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 06-06-2021, 05:32 AM   #3
Yep happens only w Echo plugged in. When strait through functions as normal.
Old 06-06-2021, 05:53 AM   #4
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
What are you towing with?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 06-06-2021, 04:17 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by GCinSC2 View Post
RMNummi,
Gary
Probably the issue, many brake controllers activate the brake lights when they activate the brakes so probably a "handshake" test of brake connection.
Old 06-10-2021, 08:26 AM   #6
1971 27' Overlander
Marysville , Ohio
RMNummi,
I went through a similar haunting with my renovation. It also only occurred when the running-lights were off. When they were on everything functioned correctly. Long of it is that I had my Electrical Engineer Father-in-law come over and help. We ended up putting a 100 ohm 10 watt resistor on the running light circuit at the 7way connection box in the trailer. Turns out this is a common issue since LEDs require so little power to operate. The slightest amount will make them light up. The fix is using a resistor that draws a small load on the running-lights when they are not on. The 100 ohm 10 watt is a commonly used resistor for automotive led "situations".
-Boom
Boom is offline   Reply With Quote
Old 06-10-2021, 05:50 PM   #7
That sounds greatÖ if I had someone that was electro saavy. Me, not so much. Towing w a Mercedes GL63Ö I agree it sure seems only to occur when lights are offÖ.itís not bright at all, just a faint pulsing every 2-3 seconds.
Old 06-10-2021, 06:08 PM   #8
GCinSC2's Avatar
Call Curt tech support.
S/OS #001
Old 06-10-2021, 07:01 PM   #9
Lost in America
mojo's Avatar
There is a pigtail connector that you place in between the umbilical cord and the TV that will solve the problem. I just happen to have one if you are interested, PM me. Used to use when I towed with a V10 diesel Touareg.
2017
Old 06-10-2021, 07:55 PM   #10
2021 27' Globetrotter
Malibu , California
Hey there. I tow with a Mercedes G550 and had the same issues. It is normal according to Curt, some European cars send a sort of test signal. There is a Curt adapter for some German cars that you can get.
https://www.etrailer.com/Custom-Fit-Vehicle-Wiring/Curt/C57003.html
By the way this only happened to me on the old Curt Echo. The new model (with the rubber tie around it) stopped doing that.
CMHM is offline   Reply With Quote
Old 06-16-2021, 06:02 AM   #11
Thanks! Just ordered the adapter. Curt confirmed Mercedes has trailer light sensor that ďpingsĒ the lights periodically.
Old 06-16-2021, 06:14 AM   #12
2019 30' Classic
2021 Atlas
Charlotte , North Carolina
Darn, I was hoping for evidence of ghosts..
LilPeanut is offline   Reply With Quote
No running lights, brake lights or trailer lights work from tow vehicle RichHog 1969 - 1973 Safari 42 05-02-2019 07:42 PM
LED Tail lights flashing RaymondFitz Lights - Interior & Exterior 24 06-04-2018 09:50 AM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Tail Lights: Flashing Slowly/Performing Poorly bgordon Lights - Interior & Exterior 13 09-10-2012 04:11 PM
Flashing marker lights hampstead38 Lights - Interior & Exterior 11 02-11-2009 09:20 AM
