Old 07-18-2020, 06:32 PM   #1
Norfolk , Virginia
Question Exterior entrance door light now working
Hello. We have a 2019 25FB International Serenity. Our external entrance light (over the door of the trailer) does not turn on when we are boondocking on 12-volt DC battery power, but all other lights inside the trailer will work. However, if we connect to shore AC power, the external light does become operational.
Has anyone else experienced this? We can't figure out if this is by design, or if we have a wiring issue. We were under the impression that all LED lights would work on 12-volt battery power.
One hypothesis: I thought maybe the external light was somehow connected to the GFCI circuit breaker (which requires either AC power or the AC inverter enabled to activate). I found NO documentation to support that hypothesis :/
Thanks in advance for any thoughts or education! I tried to attach a picture of the light below, but it's sideways. It's the light above the door outside the trailer. Thnx!
LightOfWeigh is offline   Reply With Quote
Old 07-18-2020, 07:15 PM   #2
rd tighe's Avatar
2007 25' International CCD FB
South , Texas
Images: 12
My guess is a ground problem it should work on 12 volt. Mine does. Check the screws that hold it on. Mine have come loose and caused the light not to work. Good luck.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Old 07-21-2020, 05:27 PM   #3
Norfolk , Virginia
Thanks, RD. Wouldn't be the first time I've had a screw loose
If it was a ground issue, wouldn't the light not work regardless of whether I'm on battery or shore power? For some reason it works when on shore power, but not when we're on battery. Odd indeed
Old 07-21-2020, 05:35 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
LightOfWeight, I think Dean, the previous poster is correct. I think youíve got a red herring - a coincidence that the light does work on shore power. All the lights operate on 12V.
Our door light didnít work when we got our trailer. I tapped on the housing with my hand and the light came on. A voltmeter would answer the question by testing in both scenarios. My money is on a loose connection, either ground or 12V positive lead.
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 07-21-2020, 05:40 PM   #5
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
we've had issues with ours since our 27FB was new. We've had the rivet changed but it still works intermittently. You can remove the two screws and manipulate the lense out to look inside. If I tap on it, it will come on... See if it's loose and check if moving the led light will cause it to come on. I'm going to follow along should someone else have a fix.
DoublTrouble is offline   Reply With Quote
Old 07-21-2020, 05:42 PM   #6
so, jeffmc306, is it grounded to the trailer right there at the light? How did you fix yours?
Old 07-23-2020, 12:57 PM   #7
jeffmc306's Avatar
McHenry , Illinois
Iím embarrassed to say I havenít fixed it permanently - tapping on it works but lately itís working without fail. Itís going to JC for a punch list of items and that will be one of them.
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 07-23-2020, 01:21 PM   #8
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Same problem for years...a ground issue. I used a C-clamp to completely crush the rivet to a very tight fit and it has worked ever since. Of course initially I spent the money on new lamp internals and bulb. A waste.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-23-2020, 02:50 PM   #9
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
It makes sense that the connection would be to blame. The LED's all run on the 12V system. When you are plugged into shore power, the converter is making 12V DC power and feeding it back into the system.
I really can't see Airstream going to the expense of adding 110V ballasts to the LED's to convert the AC current into DC current. Or have a separate set of wires running to the light that is only energized when the shore power is active.
It sound like the fixture is the problem like you have discovered by tapping it.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 08-10-2020, 03:33 PM   #10
We are out so I was playing with the light just now. The black wire that goes into the led/socket has a weak connection. I pressed it in, we'll see how long that fix will last. Probably needs some solder.
Old 08-21-2020, 10:01 AM   #11
So far, so good. After 800 miles, the light is still working. This is the most reliable that it has been, ever!
Entrance light not working chrismil Electrical - Systems, Generators, Batteries & Solar 0 09-11-2019 09:50 AM
Exterior Lighted Door Entrance Handle sbowman 2016 - Current Classic (all lengths) 6 09-11-2018 04:44 AM
Entrance light over front door OstrichDenve 1974 - 1979 Sovereign 0 06-18-2018 06:30 PM
LED exterior door light and waste drain light malfunction? Temperamental LP fridge fu Njg 2016 - Current International 1 04-04-2018 09:07 AM
small door on entrance door lwebb Doors & Locks 4 05-30-2006 09:11 AM
