I'd be tracing the wiring and adding another switch so the door handle is controlled separate from the porch light......
They do make LED assemblies for the porch light.
Try LEDS4RV as a source...there are several ways to go. I swapped out the bulb to a multi-LED assembly that plugs right in...
