01-03-2019, 11:58 AM
Fr Jeff
1989 29' Excella
Saginaw
, Michigan
Entry/Porch Light
I need to get access inside my 1989 Entry/Porch light to connect a LED light strip. I only see two screws up through the door drip cap to secure the light.
Might I be missing another point of attachment due to the thick caulking around the light?
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
01-03-2019, 02:02 PM
2007 22' International CCD
Corona
Mine is on a 2007, but looks very similar to yours.
To get to the interior of the light, pry around the edge of the plastic lens with a small screwdriver. As I recall, i had to push in on a corner and then work it out to get to the socket. Work slowly and gently, as I bet your plastic is even more brittle than mine...
I think there are more screws driven into the metal part from inside the shell or something. I did not have to remove the metal part to change to an LED array instead of a single-bayonet incandescent bulb. Now, hopefully, I don't have to pry the lens out again...
01-03-2019, 03:05 PM
Fr Jeff
1989 29' Excella
Saginaw
, Michigan
Thank you. Hopefully your help will allow me to tie in the LED lights to the porch light.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
01-03-2019, 03:29 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Jeff,
There is a screw on top of the porch light. I would not remove it.
You can access the light inside by prying the plastic cover out of the aluminum frame.
Here are some photos of the bulb and housing.
The black wire is 12 volt (+) and the Aluminum mount is the 12 volt Negative (-)
01-03-2019, 03:43 PM
1976 31' Sovereign
Oswego
The lens are avble. from vintage trailer supply also shell.
01-03-2019, 04:33 PM
Fr Jeff
1989 29' Excella
Saginaw
, Michigan
Do you believe it is possible to power an LED light strip from the light fixture (so as to have the strip switched from it)???
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
01-03-2019, 04:40 PM
Overkill Specialist
Dadeville
, Alabama
Yep
01-03-2019, 05:41 PM
Fr Jeff
1989 29' Excella
Saginaw
, Michigan
Great. Thanks
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
01-17-2019, 04:46 PM
Denton
, North Carolina
oil
Attachment 330974
Penetrating oil needs to be used 24 hours ahead of time and do it again right before you try to get those screws out. If you ring the heads off, your in for a hard project. They are not easy to get out once that has happened.
Dan Brown Denton NC
