Originally Posted by Bgibbs
the GFCI outlet above the kitchen counter keeps loosing power. According to the wiring diagram, this circuit also powers the fridge and outlets on the street side in the bedroom. I have checked the wiring at two of the outlets and no issues found. The fridge seems to be working on propane just fine. I know the GFCI breakers have an issue if the are tripped a few times. Any suggestions. We are starting out on a multi week trip and it is irritating.
When you say the GFCI keeps loossing power, is it safe to assume you mean the 120 volt outlet that is GFCI protected?
Unless your fridge is a lot different than mine, it does not need 120 volts to work on Propane. It only needs 12 volts for the control system.
When you say you checked other outlets wiring, how did you check the wiring? Did you plug something into the outlets to ensure they work? Outlets downstream of the GFCI may, or may not be wired to trip with the GFCI.
You never do mention what causes the GFCI to trip. It may just be working as designed.
Before leaving on your trip, plug the device into a GFCI outlet in your house. Does it trip that circuit? If so, well, you have located your problem.
