10-15-2017, 01:52 PM
2004 25' Safari
2023 30' Flying Cloud
2021 30' Flying Cloud
Green Bay
, Wisconsin
Electrical outlet cover
I need to replace the cover on my outside electrical outlet. I removed the two screws on the outlet. I couldn't pull the outlet out to remove the wires to get the outlet off so I could replace the cover.
I couldn't even move the assembly, what holds the assembly in place?
I have not seen an outlet like this with the screws in opposite corners? Can anyone give me information on replacement parts?
10-15-2017, 03:13 PM
I'm In
, Kentucky
Hi, JandLSafari, welcome to the forums. Greetings from central Kentucky.
I have not had to replace the plug but I have seen others post in here that it's a real bear to get the old one out. It's more or less glued in there. The step light is the same way. (I suspect it's something akin to the old Captain Kangaroo stuff: Fish hide and whale blubber glue )
I think (but don't guarantee) that they had to pull the plug out as far as they could get, then used a knife to start cutting away at the glue/caulk/whatever.
I found some old threads, maybe this can provide some insight
http://www.airforums.com/forums/f37/...let-52847.html
http://www.airforums.com/forums/f449...ion-90677.html
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
10-15-2017, 03:18 PM
Biloxi
, Mississippi
Mine had half a pound of caulking compound holding it in. I had to use a hack saw blade and knife to get most of it out.
MICHAEL
10-15-2017, 03:32 PM
2007 22' International CCD
Corona
Went to replace the shore power receptacle with a ‘smart plug’ version. Gobs of caulk holding it in once I removed the screws. Took forever to get it loose, 20 minutes to put the new one in. Sigh. Of course the backside is covered by the shower enclosure and can’t be gotten to easily. Grump, grump...
10-15-2017, 04:32 PM
2022 Atlas
Homosassa
Try dental floss too cut around it. It may be too tough for the floss but worth a try.
10-15-2017, 11:24 PM
Corona
I got it off by breaking the old white plastic backshell out in small pieces with a hammer and cheap wood chisel, then cutting the remaining caulk with a sharp utility knife. Sailor vocabulary wasn’t much help, but made me feel better.
This stuff was gray, thick and well cured. Dental floss would have not worked, but I’ll file that idea and remember it for the old Television antenna replacement job coming up... Gratuitous violence and big tools did...and I managed not to dent or scratch the side of the AS. Minor miracle, but I’ll take it [emoji3][emoji3]
10-16-2017, 06:03 AM
Wise Elder
2010 30' Classic
South of the river
Those are a fairly standard RV outlet that attaches to the wiring using insulation displacement connectors so that the wiring does not need to be cut and stripped. Any RV supply place will have them, either online or a physical shop.
As others have posted, the caulk makes it hard to remove things like this. In addition to the other tricks mentioned, you may find that a heat gun will help soften it enough to allow it to be removed. Be careful, though, as there is a risk of fire.
