In my '66 Safari, I had an issue with the original factory wiring for the front section of the marker lights. The 18 gauge wire was too small for the five incandescent lamps (2 bulbs each) that had been installed. The only fuse in the circuit was a 50 amp back at the truck. Fortunately there was nothing flammable inside the front end cap, because the wire burned to a crisp.
I re-wired with 14 gauge, installed LED marker lights, and you bet I put a fuse in that circuit at the trailer. The fuse should be sized to protect the wire, no matter where it is located.
