Old 06-06-2024, 05:31 AM   #1
2018 27' Globetrotter
Mooresville , North Carolina
Does anyone know how to remove this light access?
Iím trying to access the light bulb area in this bedroom light. I was able to access the other side by turning the bottom metal cover left. It turns a small bit and then drops down and pulls off but was very hard. I canít get the other side to budge. Iíve sprayed silicone and let it drop down inside to lubricate and used those rubber jar opener grasps and still no luck.
Anyone have any ideas?
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 06-06-2024, 08:56 AM   #2
aftermath's Avatar
Spokane , Washington
On mine, I twisted the outermost rim around the glass lens. I changed over to LEDs It was a pretty easy task once I figured out how to get things out.
aftermath is offline   Reply With Quote
Old 06-06-2024, 09:26 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
What aftermath said. Twist the rim off.
2019 Ford Expedition Platinum
Old 06-06-2024, 06:43 PM   #4
Thatís my problem. I was able to twist the rim on one of them but the other one wonít budge.
"Roadrunner"
Old 06-06-2024, 07:41 PM   #5
2019 30' International
Pennsylvania , Pennsylvania
https://www.amazon.com/Performance-T...s%2C82&sr=1-10
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 06-07-2024, 05:18 AM   #6
2022 27' Globetrotter
Bethlehem , Pennsylvania
Yup, twist it. I removed the cover from mine and covered the glass with this to dim them:
https://www.amazon.com/FLANCCI-Block...zcF9hdGY&psc=1
Merlintiaga is offline   Reply With Quote
Old 06-07-2024, 05:26 AM   #7
Originally Posted by majorairhead View Post
Thanks for the idea. I may have to order 2 as I have to hold both sides since the light swivels. I also want to remove it so I can insert a filter to dim the light similar to what is mentioned in the other post.
"Roadrunner"
Old 06-10-2024, 05:21 PM   #8
Thanks Majorairhead!
That part came in today and it worked. I used the larger one to grasp then top half and the smaller one to grasp the bottom ring. It broke it free. I then used the smaller one to wiggle the bottom ring and eventually work it off to insert the lens filter.
"Roadrunner"
Old 06-10-2024, 07:15 PM   #9
Totally AWESOME! Some times a little extra 'persuasion' makes things happen
Help? Anyone know how to remove this antenna mast gear? AllenF General Repair Forum 2 07-12-2020 02:38 PM
Anyone know where to find the outside access door hinges? Roothawg Vintage Kin 10 05-13-2012 04:21 PM
Anyone know how to remove fridge from bambi? R2DTube Refrigerators 0 10-12-2010 04:52 PM
Dover, DE Does anyone know? markjoandall Other Rallies & Events 1 04-30-2003 01:45 PM
Does anyone know #16019? Pahaska Our Community 15 06-30-2002 04:25 PM
