Gererally:
Sometimes the mounting screws of the
12 volt light fixtures provide a connection to the (hopefully) grounded (negative side of batteries and convertor) shell of the trailer. In that case, one side of the LED or bulb wiring will be run to a permanent fastener (screw or rivet) in the fixture. The mounting screw(s) then provide the ground to the metal of the fixture.
IF your light has a separate 'ground' wire that is connected to the ground side of the LEDs or bulbs, and it's hanging loose, put a ring terminal on it and put it under a screw into the interior aluminum, or splice it to the separate ground wire for the fixture location if there is one...see below...
If the trailer wiring has a ground lead and a supply lead run to the fixture location, carefully determine which one is ground (negative), and which is hot (positive), use a multimeter if needed, and connect accordingly.
LED fixtures tend to be sensitive to which lead is hot and which is ground--read the directions that came with the fixture, please!
