Old 05-26-2022, 05:42 PM   #1
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Can't find and reset GFI to turn plugs back on
Greetings,
We have a 2010 FB 23F Flying Cloud. There are tree plugs that run off a GFI, above the kitchen sink, in the bathroom and the plug that runs the refrigerator. They stoped working yesterday while we were out camping and I just can't seem to get them to work again. Where is the GFI for these plugs? I found one in the fuse/circuit breaker box but it doesn't seem to make a difference when I hit the reset button. Any suggestions? Do I need to pull out that circuit with GFI out and replace it?
Much thanks in advance for your expert advice.
Cameron
curnes is offline   Reply With Quote
Old 05-26-2022, 05:50 PM   #2
ITSNO60's Avatar
Tucson , AZ
Originally Posted by curnes View Post
Greetings,
Cameron
The GFCI circuit breaker does not have a reset button, that is a test button. To reset you need to force the breaker to the off position then switch it back on. Pushing the white button will only cause it to trip, as intended.
Brian
ITSNO60 is offline   Reply With Quote
Old 05-26-2022, 09:28 PM   #3
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Yup! x2.
SuperTrouper is offline   Reply With Quote
Old 05-26-2022, 09:33 PM   #4
2017 20' Flying Cloud
Williamson County , Texas
Unfortunately the outlets also seem to fail. We had one on our outdoor patio fail, one in the AS, and then to confound it, the brand new GFCI outlet I installed in our AS was bad. Finally got it sorted out. When the one in our AS bathroom went out, none of the other outlets would work until we replaced that with (second try) a good one.
GMC Canyon V6 Mallet Supercharger
Chevrolet K2500WT 454
SYC2Vette is offline   Reply With Quote
Old 05-26-2022, 09:55 PM   #5
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
So .... backing up a bit:
A GFCI looks for leakage current to ground. If it sees leakage, it trips.
Leakage can be from somebody grabbing a wire ( yikes !!! ) or it can be from a spider web inside an outlet. The GFCI has no way of telling one from the other.
These outlets are typically daisy chained together. One device protects multiple outlets. Dirt in any outlet can trip the device and turn off all the outlets. The device has no way to just turn off one outlet and let the others run.
Resetting the typical GFCI device requires that power be present. In an RV, this isn't always the case. Cycling the device with no power applied may not reset the gizmo.
The outlets that go downstream of a GFCI device are no different than any other outlet in the trailer (other than a sticker ....). There is nothing at all special about them. All of the smarts are in the single GFCI device that is "upstream" of those outlets.
First step in any RV GFCI mystery is to spray clean the outlets with your favorite "stuff". WD40 is one choice. There are others. Only use sprays designed for this sort of thing. A normal cleaning spray like Windex or 409 will cause all sorts of problems.
Old 05-27-2022, 07:00 AM   #6
ITSNO60's Avatar
Tucson , AZ
The OP has a GFCI breaker which can also trip on overload, not just a ground fault.
Brian
Old 05-27-2022, 08:35 AM   #7
aftermath's Avatar
Spokane , Washington
Cameron, in my older 25FB this happened to me. I went to the circuit breaker box and tried to reset the GFCI breaker and nothing happened. I replaced the breaker and bingo, the wife thinks it was magic. These, as all other breakers, can go bad for whatever reason. Mine did and it was an easy fix.
aftermath is online now   Reply With Quote
Old 05-27-2022, 11:10 AM   #8
curnes's Avatar
Thanks for all the responses. I reset the breaker with the power off and that seemed to do the trick. As alway, I learned a bunch from your responses and will be better equipped to repair the next problem.
Old 05-27-2022, 01:28 PM   #9
CruizinDux's Avatar
Washington , Missouri
Greetings,
Cameron, congrats on the fix. Just a follow up, in our 20, the exterior dupe is part of the GFIC circuit
Go Dux/Beavs
WashMoBob
CruizinDux is online now   Reply With Quote
Where is GFI reset? David2638 Batteries, Univolts, Converters & Inverters 17 02-25-2021 08:37 AM
Back turn signal light bulb broke and can not get out ArgosyMinuet All Argosy Trailers 5 04-22-2013 04:36 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Can't turn back now,,, steve206 Full-Timing 9 05-12-2010 07:56 PM
How Can it Be? 2 Plugs work, 2 Plugs dont Aluminumb Electrical - Systems, Generators, Batteries & Solar 10 07-27-2009 07:44 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
