Old 10-12-2021, 04:19 PM   #1
2021 27' Flying Cloud
Alpine , WY
Blue LED lights
Does anyone know an option to replace the white led lightbulbs with blue ones? I have a 2022 Flying Cloud a d want to change the color on some zones.
Harry Hedaya is offline   Reply With Quote
Old 10-12-2021, 05:23 PM   #2
Mollysdad's Avatar
The simplest solution is to locate some "gel" material used for film industry lighting. Pop off the light lens and ring, cut gels with scissors, insert and voila'.
Here's a sample from Amazon. It might take a bit of experimenting to get the blue you're looking for. Roscoe is the big supplier.
https://www.amazon.com/Rosco-Roscolu...077252&sr=8-30
Old 10-12-2021, 05:58 PM   #3
Dennis C's Avatar
Evergreen , Colorado
Exactly. I did this last weekend and it was quite easy. The hardest part is choosing the right gel color to get the desired effect. I chose one that was a little too pink. I've got a new one coming that should be more of a warm white. Fortunately it's fast, easy, and inexpensive to experiment with different gels.
Dennis
Current: Newmar Ventana 3715 (6,265 lbs. cargo capacity )
Past: Airstream International Serenity 23FB
Dennis C is offline   Reply With Quote
Old 10-12-2021, 07:31 PM   #4
Fox-trot's Avatar
2022 23' International
Seabeck , Washington
Very cool! I just added a swatch book of these to my airstream goodies wish list :-). Thank you!
Fox-trot is offline   Reply With Quote
Old 10-13-2021, 07:31 AM   #5
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Coming from stage work, I did the same to "warm" the cool light of my replacement LEDs. While you are at it you might want to add a layer of "frost" or diffusion gel to your color to smooth the light. The glass lens bumps on my ceiling lights causes color refraction and patterns on the walls of the galley and the frost gel solves this problem. -Brad
SuperTrouper is offline   Reply With Quote
LED Lights... Too blue?? Harsh in the morning... Plasma800 2011 - 2015 International 42 07-28-2018 07:47 AM
Blue LED lights burned out Triumphdude General Repair Forum 1 05-26-2016 02:12 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
