Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 09-24-2020, 08:25 AM   #1
1968 17' Caravel
San Antonio , Texas
Blinking side round white porch light.
1968 airstream caravel 17’. The round white light (porch) by the entrance is blinking. Is it supposed to? Anyone had this issue? Never really used it before. It’s not flickering, but a strong steady blink while I’m plugged in at home charging the batteries. Any advice? Thanks.
Cordovac is offline   Reply With Quote
Old 10-25-2020, 02:44 AM   #2
1969 27' Overlander
Eugene , Oregon
Bulb could be going out, or switch issues.
Also connection at the bulb can be an issue. Get a $7-$10 tube of Dielectric Grease and coating the metal in the lights will help protect the metal parts and increase the connectivity to keep the lights working.
gdesign is offline   Reply With Quote
Old 10-25-2020, 06:11 AM   #3
1966 22' Safari
Fredericksburg , Texas
The hot on your Scare Light is normally daisy-chained with all your running lights. They’re individually grounded to the aluminum shell At each fixture. You can take the lens off and see if the ground wire is visible. If not, you may have to take the can out to get to the wire. Make sure the wire has good, tight contact ground connection and the bulb socket is free of corrosion. As stated, Dielectric Grease is a good thing. Good luck
Bubba L is offline   Reply With Quote
green blinking light in parallax power box Peggy Raffer Electrical - Systems, Generators, Batteries & Solar 0 03-13-2017 06:34 PM
Warm white patio/porch/scare light thomasj Lights - Interior & Exterior 12 11-09-2016 06:58 PM
Systems Monitor - blinking red light? time2play 2009-2015 Flying Cloud 0 05-18-2013 07:19 PM
Round and Round She Goes thecatsandi On The Road... 21 04-03-2007 03:36 PM
