Old 06-08-2020, 05:42 PM   #1
2016 30' Classic
DRAPER , Utah
Battery Disconnect or Converter Problem?
I've not seen my problem on other threads...
We have 2016 30' Classic with the "old school" battery disconnect switch. Out of the blue, when plugged into shoreline power, but with the disconnect switch in the "store" position all 12V functions (lights, fans, etc.) no longer work, but all 110V functions and outlets DO work, AND the red light goes off when I switch to "store." When I switch to "use" the red light comes on and 12V systems work as do 110V systems. However, I'm not sure batteries are getting charged since I use an external Battery Tender Plus 4A smart charger.
Solenoid makes "clicking" sounds, all breakers in the panel are on and seem operational.
Has anyone seen something like this?
utcruzin is offline   Reply With Quote
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Converter disconnect switch nm1oqrz Batteries, Univolts, Converters & Inverters 7 08-08-2013 06:48 AM
Low voltage... converter or battery problem? patrickdylan Batteries, Univolts, Converters & Inverters 5 08-22-2009 09:24 PM
Safari Battery Disconnect problem Silverbee Batteries, Univolts, Converters & Inverters 1 05-04-2007 09:24 PM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
