Old 05-22-2020, 12:10 PM   #1
2018 30' Classic
Williamsburg , VA
Bathroom light won't turn on
Hello, I have a 2018 Classic and the bathroom light won't turn on. The firefly states it is on along with the panel in the bathroom but the lights aren't on. The green LED on the G6A Control Panel lights up for number 13 yet no light is on. Any ideas?
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 05-22-2020, 01:01 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Is there an actual slide switch on the lights like in other models like the Flying Cloud?
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-22-2020, 01:08 PM   #3
2018 30' Classic
Williamsburg , VA
No there is not. Thank you for the suggestion though. I have turned off 12v and 120v, then reapplied power and still the same thing. I'm not sure where the relays or the fuses are for this. I have looked where the other power items are like under the closet and the dinette cushion by the TV. Puzzling, and I don't have a multi-meter on me so I'm troubleshooting in the dark.
2018 Classic 30
2012 F250 6.7l
Old 05-22-2020, 01:23 PM   #4
2018 30' Classic
Williamsburg , VA
Just borrowed a camping neighbors multi-meter. No voltage to either light.
2018 Classic 30
2012 F250 6.7l
Old 05-22-2020, 02:47 PM   #5
2018 30' Classic
Williamsburg , VA
Found the issue. It was a connector by the water pump under the fridge. I don't like that connector style, both ends slide together. Wiggling it makes the light turn on and off. They are modular connectors and there was three connectors with only two wires. So I removed the empty one and reconnected and it appears to be working fine. If it happens again I'll change to a better connector type.
2018 Classic 30
2012 F250 6.7l
Turn bathroom light on loose TV Signal Jkreis Audio, Video & TV 24 08-07-2019 08:17 AM
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 11:26 AM
Google Turn-by-Turn Navigation techiej Electronics & Connectivity 19 12-27-2012 05:55 AM
Running light won't turn off terryd Lights - Interior & Exterior 4 07-20-2011 07:41 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
