Old 04-20-2025, 05:52 PM   #1
2018 22' Sport
Salem , OR
Question Bath ceiling light doesn't work. 2018 22FB Sport.
I replaced the ceiling light fixture, no help. I don't know really how to identify which fuse is associated with it. Everything else in the rig works, and it seems unlikely that the bathroom light would have it's own fuse. Could it be the water heater?! I don't know if the water heater is working or not because we never use it and we are just out of storage, the tank is empty and needs cleaning. Thanks for helping me if you can!
Rob Gramenz is offline   Reply With Quote
Old 04-20-2025, 08:22 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 199
RE: Bath Ceiling Light Doesn't Work. 2018 22FB Sport
Greetings Rob Gramenz!
Your bathroom light is in all probability 12-volt DC, and while the electronic spark igniter for the water heater is also 12-volt DC I wouldn't anticipate that they shared the same fuse or 12-volt breaker.
If you didn't get the owners' manual with your trailer, you can obtain a pdf copy from Airstream's website at:
2018 Airstream Sport Owners' Manual
You can also download a pdf copy of the parts book from the Airstream website as well, at:
2018 Airstream Sport Parts Manual
The owners' manual should help in identifying which fuse controls that light's circuit, and it may be the same circuit as the spark igniter for the water heater -- a clue may be if the switches for both the light and the water heater are near each other.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 04-21-2025, 06:11 AM   #3
2025 25' Trade Wind
Beaver Dam , Wisconsin
Use your voltmeter before choosing things to replace.
Loose or corroded connection
Defective light switch
Blown fuse
Defective LED fixture
LED fixture wired backwards.
Post make and model of fuse panel for better advice. Many used by AS have a small red light that indicates a blown fuse when the appliance on that circuit is turned "ON".
Paul Bristol - In the wind!
2025 AirStream Trade Wind
2024 Ford Expedition Max LS with factory towing package
PaulBristol is offline   Reply With Quote
Tongue jack not working, 12 volt tested and verified but even the light doesn't work? 7th Heaven Jacks, Stabilizers, Lifting and Leveling 13 07-23-2023 01:41 PM
Left turn light doesn’t work groetschel Lights - Interior & Exterior 1 05-17-2023 06:08 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Refrigerator light doesn't work- m.hony General Repair Forum 31 07-16-2015 12:58 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
