Old 09-22-2019, 10:22 PM   #21
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Originally Posted by jimmini View Post
After putting LED lights strips in some of my inside fluorescent light I now have static on my radio when the lights are on.
I have replaced the twist in bulbs in the bath with twist in bright white LEDs and we love them.No static on radio from them.
Jimini, if the plug on the radio is not polarized try unplugging it and flipping it over then plug it back in. Most likely tho the plug will be polarized unless the radio is an antique.
You are getting the static from the ballasts, there are two kinds of LED replacements for fluorescent fixtures, one where you just pop them in and keep using the ballast, or you can buy ones where you bypass the ballast and connect the LED directly to line voltage.
Brian
ITSNO60 is offline   Reply With Quote
Old 09-25-2019, 11:21 AM   #22
1981 31' Excella II
New Market , Alabama
I ended up replacing most of them with my spares and one new LED marker light I bought as a sample. For some reason most of the failure were yellow. I have ordered a whole set of incandescent lights to use as replacement as the LED's fail. Nothing is made to last.
Perry
To LED or not to LED? SilverHoot Lights - Interior & Exterior 56 10-03-2011 01:15 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
Behold, the Golden Airstream... idahosafari Our Community 6 10-10-2003 12:01 PM
Golden Avion - what is it? JimC Our Community 2 05-12-2003 03:11 PM
