Old 04-12-2024, 07:16 AM   #1
2001 30' Classic S/O
Houston , Texas
Access license plate light bulb
How do I access the license plate light bulb on a 2001 30' Classic? The plate holder is an insert and is sealed to the body. Before removing the insert I want to make sure the light housing does not open. It is not obvious to me how to open the light housing.
acbillard is offline   Reply With Quote
Old 04-13-2024, 09:04 PM   #2
Moreland , Georgia
I'm not an AS person, but I peruse the forum sometimes for ideas. See my signature for my rig.
Anyhow, I know AS used Bargman lighting at one time, and if it looks like this, the light has to be removed from the trailer first as the light socket goes in from the back. Find an LED 168 compatible lamp so you don't have to deal with it for a long time to come.
https://www.amazon.com/gp/product/B00C10NIH4
This is a bottom view of the fixture and it fits over a metal plate bracket.
If you gotta remove it, it might be worth installing a new one.
Lumtronics and Kaper both make what looks like perfect clones of the Bargman.
https://www.amazon.com/Kaper-II-1M-B.../dp/B0113XR0P0
https://www.amazon.com/dp/B00QU79WUQ/?th=1
Charles
'03 Ram 2500 CTD, 5.9L HO PacBrake six speed std cab long bed Leer top and 2008 BigfootRV 21RB trailer.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 04-14-2024, 07:45 AM   #3
Houston , Texas
Solved
Solved. The light fixture (not bulb, need to replace the fixture) snaps into a 1 1/4" hole in the top of the license plate insert. I did not want to start prying until I understood how it fit. I saw another airstream with the same fixture which was slightly looser, and it was obvious how it fit. Thanks.
turn signal light bulb replacement...bulb not turning ArgosyMinuet All Argosy Trailers 5 01-01-2021 10:21 PM
License plate bulb for 1978 Safari eb4tx Lights - Interior & Exterior 3 03-01-2015 06:44 AM
license plate light gasket Isadora Lights - Interior & Exterior 8 04-15-2008 09:32 PM
License plate light drain? vhord Lights - Interior & Exterior 2 03-27-2008 05:52 PM
