Old 09-26-2021, 07:32 PM   #1
1976 Argosy 26
Reidsville , North Carolina
76 argosy no rear tail lights, help
So close to finish. Rear lights previously worked, took off rear taillight lip to repair cracks, reinstalled, painted rv, restored rear bath. Last pm went to hook up trailer and no rear lights at all on lip, yes has clearance lights. Where should I start tracing? Are there fuses or a main ground that would be easy to start with. My main concern is I remodeled the rear bath and did some drilling for new pop rivets for the original molding. Any suggestions would be greatly appreciated. I’m not an electrician so this is difficult to understand.
76argosy is offline   Reply With Quote
Old 09-26-2021, 11:39 PM   #2
Biggmixx's Avatar
1978 Argosy 30
Auburn , Washington
My trailer had a fuse block for the 7pin plug on the street side. It was under the arm rest of the gaucho. I've had to clean the holders since they tended to get rusty. Another time I had problems with the lights was when I dropped the 7 pin into the gravel. I use dielectric grease and it picked up a small pebble. I didn't notice it and plugged it in. It bent the contact and caused the lights not to work. Either place is a good place to start because it is easy to check for voltage there.
Dave
Biggmixx is offline   Reply With Quote
REAR TAIL LIGHTS: Larger to fit Rear End Size Ray Eklund Bumpers & Bumper Storage 0 06-14-2021 12:51 PM
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 10:05 AM
Anyone know of LEDs for the rear marker lights on mid '70s on the tail lights? Mixter Lights - Interior & Exterior 8 11-11-2014 08:27 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
