Old 01-16-2018, 06:18 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
75 Overlander Exterior Lights Circuit Breakers
My Overlander has a 7 pin receptacle on the front of the trailer. So you plug the umbilical cord in to the trailer, and then into the tow vehicle. I have never seen such an arrangement before. You can take your umbilical with you into the restaurant. Hang it around your neck like a snake. I feel it doubles the chance of trouble due to a loose connection or corrosion in one of the plugs. My old 66 and our 86 are hard wired in to the trailer.
So I aim to hard wire the 75 Overlander 7 pin umbilical cord in the same way. This trailer has 12v circuit breakers on many of the 7 circuits from the tow vehicle to the trailer. They are 1. brake lights, 2 tail lights, 3 turn signals, 4 brakes, 5 marker lights, 6 back up lights, 7 battery charging, and ground wire. I believe these are old fashioned "thermo"style breakers than open when the element gets hot from an overloaded circuit. Then they close back up when they cool down. I much prefer fuses as they go open and stay open until you find the problem.
Most tow vehicles have fuse protection on the 7 pin circuits too.
Do I need circuit protection for the exterior trailer lights? Are fuses adequate? Has anyone else eliminated the trailer plug and hard wired the umbilical cord to the trailer?
David
PS I am "double posting" this question; both here as well as my Overlander Improvements Journal thread. I'm hopeful someone can help me out.
Name:	1801 Electrical 7 Pin Breakers (Small).JPG
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Circuit breakers in '09 International 25FB donna01 Electrical - Systems, Generators, Batteries & Solar 6 03-13-2011 02:15 PM
Circuit Breakers Alumanutz Lights - Interior & Exterior 1 09-11-2008 08:02 PM
Circuit Breakers Tripping bgarver Electrical - Systems, Generators, Batteries & Solar 2 11-16-2007 10:52 PM
Circuit breakers,94 33ft Motor Yacht rayschell Batteries, Univolts, Converters & Inverters 4 07-10-2005 11:35 AM
Electric Heaters Tripping Circuit Breakers streamlean General Motorhome Topics 11 01-20-2004 09:29 PM
