Old 09-24-2024, 10:51 AM   #1
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
27fb lost power to closet led light
Would anyone out there know the source of power is for the closet light in a 27FB ?
I've tested the led panel continuity, OK and then the wires leading to the light fixture and ,,,,she's not hot. Visually traced it down into the bottom of the closet where the cubby is for the water pump etc and gave her a slight tug but seems to disappear under.
Laurence
LAWBC is online now   Reply With Quote
Old 09-25-2024, 04:36 PM   #2
LAWBC's Avatar
****Found the problem, LED Panel fried and operator error o original test, retested power to wire and she's 12 volts+.
Laurence
LED strip lights in hall closet saraed Lights - Interior & Exterior 8 06-24-2022 10:43 AM
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 12:26 PM
LED exterior door light and waste drain light malfunction? Temperamental LP fridge fu Njg 2016 - Current International 1 04-04-2018 10:07 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
