Lights flickered and went out. As I was pulling the switch they flickered again and came on. Checked the fuse in the wall and replaced the quick connects with crimp connectors put it back together and worked fine. Next day flipped the switch and nothing, again pulled the switch checked the connections shook the wiring harness-nothing. I have
12v at the power wire and ground wire has continuity. Bypassed the switch to the light wire and nothing.
So question being does anyone know how that light wire is routed? It runs between the shower stall and the bedroom wall toward the tv and the outlets on the wall. I assume it then goes up to the ceiling lights. I pulled down the one light closest to the switch (mouse trapped my fingers) and that light just had 2 wires, where do the other 3 lights get their power?
Any ideas/help is appreciated.
