Old 09-15-2019, 04:16 PM   #1
1989 29' Land Yacht
St. Catharines , Ontario
12volt LED light strip
Question for the Electricians out there. I'm considering installing an Illum LED light strip from Home Depot. I want to eliminate the transformer and wire it directly to a 12V DC circuit. The transformer output is 12V 2amp. Is this possible?
ktmkirby is offline   Reply With Quote
Old 09-15-2019, 04:24 PM   #2
1986 31' Sovereign
Miami , Florida
Sure. Just get the polarity correct ó diodes hate reverse current.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 09-15-2019, 04:32 PM   #3
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Just did a LED strip light project to light up the inside of the medicine cabinet, and to add more lighting to the closet, especially the rear of it. Got these on Amazon. A 16' strip of LED light. Made to be cut to any length. About the width of Scotch tape. Peel off sticky back, super easy install. It's made for 12 volts so wiring is a breeze.
https://www.amazon.com/gp/aw/d/B075L...b_b_asin_title
You'll need these little connectors too.
https://www.amazon.com/gp/aw/d/B01DM...b_b_asin_title
kscherzi is offline   Reply With Quote
Old 11-10-2019, 10:52 PM   #4
1959 28' Ambassador
Victoria , Minnesota
Yup. Works great. However those remote kits do not. They donít seem to last very long so Iíve changed to higher end units whenever I use them.
Kyacker is offline   Reply With Quote
Old 08-04-2020, 07:59 PM   #5
EL MONTE , California
Was it due to the voltage hike when the engine was turned on?
withair is offline   Reply With Quote
Old 08-04-2020, 09:02 PM   #6
1976 31' Excella 500
Crewe , Virginia
You can definitely wire them in directly to your existing 12v circuit. I had those 70's florescent dome lights and the ballasts had gone bad in them. I chose to replace with bright white......kind of kept the original glow. Anyway, I just cut them to the length I needed, wired them in with the included adapter on one side, had to solder in 2 wires on the other side (only 1 adapter came with the strip) and then peeled and stuck them on the original light mounts. I did lay a full strip of clear Gorilla duct tape over them just for an extra secure. I did the lighting on the front and rear domes. Good luck with your project!
Dspchef is offline   Reply With Quote
12v
LED strip light added under bed side upper cabinets waninae39 2005 and newer - Bambi all models 0 09-09-2019 09:15 PM
LED light strip trumpetguy Airstream Trailer Forums 7 03-21-2018 06:58 PM
Awning LED Light Strip factory install silvereagle2 Lights - Interior & Exterior 36 04-19-2016 12:56 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
