I'm planning a Showermiser install and want to tap the recirc line into the FW tank fill line. Where is the best place to do that - not sure what panel I need to remove to get access. I've a 2023 25' FBT.
I suspect that you could hook it into the suction side (tank side) of the water pump. What I mean is the water line that goes from the fresh water tank to the water pump.
Also I assume you would only use the shower miser when not hooked up to city water. Otherwise you could overfill the fresh water tank.
IMO, this is actually a side-benefit of having the shower miser - being able to fill the water tank without hooking a second hose to the water fill inlet.
Yup, I use ot to fill the fresh tank frequently.
-Rich-
