Old 02-09-2019, 07:30 AM   #1
Rhino33's Avatar
1980 31' International
1966 22' Safari
Cincinnati , Ohio
What is this plumbing fitting?
We are working on replacing the copper tubing on our 1966 22' Safari, as the faucets in the shower and bathroom sink are leaking. The attached photo is taken from in the bathtub looking into the tiny access area under the bathroom sink. What is the capped off looking fitting in the lower section? The two lines going into the wood are to the bathroom sink faucet, but I am not sure about this odd one...
Thanks so much!
Name:	IMG_0468 edited.jpg
Robb, Jenn & The Brown Dog (Dex)
Maizie, The Black Dog, May You Rest Peacefully
1980 International 31
1966 Safari 22
WBCCI #4447
AIR #70157
Rhino33 is offline   Reply With Quote
Old 02-09-2019, 08:41 AM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
No experience with the vintage trailers but looks possibly like a vacuum breaker, does it come from the bath faucet?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 02-09-2019, 02:47 PM   #3
Long Island , New York
Is that fitting close to the city water feed? Similar to what Alan said . . . maybe an anti-siphon valve to prevent the trailer’s water from going back into the city water supply in the event of a pressure drop in the system? Seems unusual for an older unit IMO. Maybe a prior owner re-plumbed things?
Peter
Old 02-09-2019, 04:00 PM   #4
stephenh2's Avatar
Tyler , Texas
I'd guess a water hammer arrestor, especially if the orientation is with the cap end pointing skyward.
Home again in Tyler, Texas
The Rose City
stephenh2 is offline   Reply With Quote
Old 02-10-2019, 11:41 AM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
That is a vacuum breaker. My 66 Tradewind had one (see photo). I removed it as we went with a porta potty.
I replaced all the plumbing lines with Pex. There are writeups and photos in my thread- Dan’s 66 Tradewind Improvements.
DanClick image for larger version
Old 02-11-2019, 05:34 AM   #6
Rhino33's Avatar
1966 22' Safari
Cincinnati , Ohio
The fitting is oriented upright, with the cap end pointing towards the underside of the bathroom sink (which in this photo is the plywood). If this is a breaker, do we need to replace it when we replace the copper lines with PEX? There is a bell shaped regulator just inside of the city water connection, which we were going to replace to prevent back-flow to the city hookup, but now I’m not sure if we need this fitting?
Thank you for all of your help (and Dan for the info on your water line replacement), we appreciate it!
1966 Safari 22
WBCCI #4447
AIR #70157
Old 02-11-2019, 06:39 AM   #7
1996 25' Excella
Tillsonburg , Ontario
If it is a vacuum breaker you don't need it since there is usually a n antisyphpn on the Park water tap. New trailers usually have one only on the black tank flush fitting
JCW
JCWDCW is offline   Reply With Quote
Old 02-19-2019, 03:46 AM   #8
Rhino33's Avatar
1966 22' Safari
Cincinnati , Ohio
Thank you all for your help! I will eliminate it when we install the new PEX lines.
1966 Safari 22
WBCCI #4447
AIR #70157
63 tradewind black water tank/toilet fitting durans54 Waste Systems, Tanks & Totes 5 04-29-2006 01:16 PM
Dump valve fitting for 63 Safari srgntpepper Waste Systems, Tanks & Totes 5 06-05-2005 05:36 PM
fitting a 'Fantastic' fan in a 66 hickam Roof Vents, Skylights & Fans 4 04-18-2005 11:07 AM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
Drain Fitting conversion? Recommendations? Jabba Waste Systems, Tanks & Totes 3 07-11-2003 05:30 PM
