Old 08-19-2019, 02:01 PM   #1
F/t Airstream Newby
NTENDED's Avatar
2008 23' Safari SE
Campo , California
Red face Water pump repair 2008 AS Safari 23 ft.
Been full time living in my 23 ft. Safari 1 1/2 years in rural san Diego county. Had just filled water tank when water pump just stopped. Need info of where pump is located & what kind of pump to buy to replace it. Also is this a job I can do myself? TIA.
Patty O'Shea 🍀
NTENDED is offline   Reply With Quote
Old 08-19-2019, 03:31 PM   #2
2019 27' Globetrotter
Missouri Valley , Iowa
Maybe you tripped a breaker or blew a fuse in the 12V system. That's the first thing to check. If the pump is bad its not too difficult to replace -- as long as the access is good and you are a little bit handy. I can't help you on the location, not having had that model before. The owners manual should tell you where to look for the pump and the 12V panel.
Dan
Farmer Dan is offline   Reply With Quote
Old 08-19-2019, 03:46 PM   #3
I found the owners manual on line. It says pump is behind the lower front face panel on the roadside wardrobe. It is hinged or, on the front bed model, the panel is removable with a pressure catch and the lower wardrobe shelf is removable.
Dan
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
2008 Safari Sport 17' water pump dlb435 Water Heaters, Filters & Pumps 0 03-02-2014 07:43 AM
2008 17' Safari Sport Loud Water Pump Dale Monroe 2008 Safari SE 5 08-22-2010 07:57 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
