Old 08-16-2023, 09:25 AM   #1
2004 25' Safari
Newmarket , Ontario
Trap Adjustment Aqua-Magic Toilette
2004 Safari. Came with the above toilette. One foot pedal operation. Depress half way and the water valve opens filling the bowl. Depress fully and the trap opens and the bowl empties.
When the pedal is depressed fully the valve opens but sticks open. Appears to be opening too far and catching on the edge of the drain hole. It won't return.
Want to adjust the mechanism so that the trap doesn't fully open when the foot pedal is fully depressed.
Anyone else run into this problem? Does the toilette need to be removed in order to make any adjustments.
Thnx
Jake
Jake is offline   Reply With Quote
Toilet trap door/slide adjustment grannyred Sinks, Showers & Toilets 0 11-30-2006 04:40 PM
1972 Thetford Aqua Magic 30 cameront120 Sinks, Showers & Toilets 2 04-25-2006 08:19 PM
Replacement Toilet for Thetford Aqua Magic? JeepinAudiophile Sinks, Showers & Toilets 1 09-20-2004 11:05 AM
toilet:Sealand vs Aqua Magic dogwood Sinks, Showers & Toilets 8 09-02-2004 07:46 PM
Aqua Magic Toilet - 68 Globe Trotter Bryanhu Sinks, Showers & Toilets 0 06-30-2003 01:29 PM
