Old 08-08-2023, 09:42 AM   #1
Port Tobacco , Maryland
Toilet water supply leak
I have intermittent leak from the water supply for the toilet. This occurs both from the freshwater tank and when hooked up to city water. Has anyone else experienced this, and does anyone know the purpose of the black fitting which appears in the white water line?
2018 Flying Cloud 25 ft FB
CHunsaker is offline   Reply With Quote
Old 08-08-2023, 11:10 AM   #2
Trailer Sold, Waving
Acheron2010's Avatar
2019 26' Flying Cloud
Stettler , Alberta
Are you saying the valve is leaking and continuing to fill the toilet, or is there a leak from the piping or valve dripping on the floor leading to the toilet?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 08-09-2023, 04:57 AM   #3
Water is leaking onto the floor. Small drips which seem to be coming from the black valve
Old 08-09-2023, 07:31 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Photo?
Lots of black valves and fittings in a trailer.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 08-09-2023, 10:49 AM   #5
2017 25' International
Portland , Oregon
If it's a drip anywhere in the vicinity of where the water line enters the toilet, you very likely just need a new dometic cartridge. Very easy fix that will take less than 15 minutes. Camping World, eTrailer, and Home Depot all carry them, IIRC it will cost around $60 for the part.
Good Luck!
PDX007 is offline   Reply With Quote
Old 08-09-2023, 11:26 AM   #6
starlite29's Avatar
2019 25' Flying Cloud
Decatur , Georgia
Two "black valves" you could be referring to:
1) shutoff valve on the floor, on the cabinet side of toilet. If this is leaking, it simply needs to be removed and replaced.
2) black rubber seal where the vacuum breaker enters the toilet. Could be dried out, new one can be obtained from Dometic or as part of the vacuum breaker replacement kit.
Agree with above posters that photos or more detail would be helpful.
starlite29 is offline   Reply With Quote
Old 08-09-2023, 04:27 PM   #7
Tbeck11931's Avatar
1990 34' Limited
2013 27' FB International
Conroe , Texas
Amazon store
Halotronics RV Water Valve Replacement Kit for Pedal-Flush Toilets - Compatible with Sealand Dometic 300, 301 310,
Just look up your Dometic model #
Tbeck11931 is offline   Reply With Quote
Old 08-09-2023, 04:28 PM   #8
2017 25' Flying Cloud
Woodway , Texas
Dometic Toilet Drips...Occasionally
Check under each with a paper towel. If it's the black valve, you'll need to replace it with one compatible with PEX using a crimping tool for same. They're cheap enough and a good addition to your toolbox.
If its the valve just behind the R side of the seat hinge, you can get a Dometic one quick enough on Amazon for about $47 and with Prime, of course, no shipping. I sourced mine from a local RV supply for $37 but that was 3 years ago.
emelaich01 is offline   Reply With Quote
Old 08-09-2023, 05:35 PM   #9
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
Agree with others. Since intermittent, likely the dometic water valve needs replacing. I replaced mine last year on our 2018. If I let the flush pedal snap back up, it wouldn't drip, but if slowly released the pedal, it would sometimes leak by.
StuartsDad is offline   Reply With Quote
Old 08-09-2023, 11:47 PM   #10
Mach5's Avatar
Woodland , California
I had the same issue, turned out to be leaking at the hose connecting the flush valve to the bowl. I believe the pex fitting the factory uses to attach the hose to the valve is not correct for the hose material. The fix was to use a proper hose clamp at this connection. No more leak. See this thread for details:
https://www.airforums.com/forums/f446/oem-vs-amazon-toilet-valve-225258.html#post2517050
Mach5 is offline   Reply With Quote
Old 08-10-2023, 04:57 AM   #11
Sorry I didn’t post pictures. I took them but couldn’t figure out how to post them from my phone.
Looks like the shutoff valve (which doesn’t turn). I will replace it.
Thank you all very much.
Old 08-13-2023, 12:37 PM   #12
gator.bigfoot's Avatar
KW , Ontario
I had a similar problem it was the shower head attached to the toilet was leaking. Replaced it and problem solved
gator.bigfoot is offline   Reply With Quote
Old 08-13-2023, 09:36 PM   #13
2017 30' International
Lincolnwood , Illinois
water leak
I have one as well. One of my pex fittings is loose.
Also , the fitting that goes in to the toilet bowl had a small crack.
Bought replacement on Amazon. problem solved. Cheap on amazon, under
$20. $75 at airstream dealer in Naperville. What a rip off for a $2 piece of plastic.
Bought pex tool and fitting on amazon. Will be repaired tomorrow.
Milo1952 is offline   Reply With Quote
Black water increasing fast & toilet water supply leak Kendra Clapp Waste Systems, Tanks & Totes 6 10-02-2020 07:55 AM
toilet water supply line leak AlamoRunner Sinks, Showers & Toilets 1 11-01-2015 01:08 PM
Pex fitting leak - toilet supply line eberrobw Sinks, Showers & Toilets 9 04-13-2012 09:55 AM
Where's the water supply on the Thetford toilet? bbqmama Sinks, Showers & Toilets 1 01-28-2012 10:57 PM
toilet supply leak???? help bubbainsd Plumbing - Systems & Fixtures 7 01-03-2008 03:49 AM
