Old 06-05-2023, 02:46 PM   #1
2022 27' Globetrotter
bremerton , Washington
Toilet not holding seal constantly flushing
So we have a Globetrotter 2022 FBQ, and our toilet started to get clogged from some TP that we were trying out. Well we took a stick to push down the tp and unclog it. Well while pulling out the stick we are not sure if it hit the gasket or something, because it started to constantly flush and drain as if the valve w-as held open. It looked like there was a gap between the valve and gasket. So i pulled out the gasket and cleaned it. re-inserted it, but it seems that water is still getting past it and going around the valve. It seems like its an easy fix. I just dont know what I need to do.
Sakura is offline   Reply With Quote
Old 06-05-2023, 06:56 PM   #2
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Toilet Work
Please post a picture of your toilet. There were several Thetford models used in Airstreams.
I have an Aqua Magic II. I replaced the waste ball seal and the floor closet seal last year and then this Spring, the white waste ball would not retract and the pedal froze.
It was easier to replace the whole toilet than to fix it.
Let us know what you have. Considering the newness of your trailer, the manufacturer Thetford may help you under warranty if it is a failure.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 06-05-2023, 07:11 PM   #3
2018 30' Flying Cloud
Springfield , Ohio
I believe your toilet seal just pulls off of the ball and is easily replaced. You may have dislodged the seal and it will work fine once it's put back into place. I've attached a YouTube video link that shows hot it's done.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Water Draining from White Drain line When Flushing Toilet hoagy_007 Plumbing - Systems & Fixtures 6 06-28-2018 12:01 PM
Flushing the toilet pumps (fresh) water on the ground mstrem Plumbing - Systems & Fixtures 2 09-03-2016 08:48 PM
Keeping Airstream constantly warm when not using Lothlorian General Repair Forum 23 10-05-2015 06:00 AM
Black colored water when flushing toilet Mikec1231 Plumbing - Systems & Fixtures 3 06-20-2013 06:09 PM
2012 FC 25FB: Winterizing: "toilet-flushing valve"? barrettjl Winterizing, Storage, Carports & Covers 6 11-14-2012 10:47 PM
