Old 02-25-2024, 12:33 PM   #1
2020 27' Flying Cloud
Norcross , Georgia
Toilet not flushing correctly
Even with good water pressure from the outside hose and good pressure at all faucets the toilet doesn't seem to have much pressure at all.
We've blown out the toilet lines, but turned out to be temporary fix.
Any suggestions?
JavaJay123 is offline   Reply With Quote
Old 02-25-2024, 03:22 PM   #2
2017 25' International
West Lake Hills , Texas
Silly question from me...
Is the cut-off valve fully open?
Fungus is offline   Reply With Quote
Old 02-25-2024, 04:07 PM   #3
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
If you blew the lines out and it helped temporarily that is a classic case of a clogged inlet. You don't say which toilet you have but the pic is from a Dometic 300 series.
Name:	toilet supply.jpg
Brian
ITSNO60 is offline   Reply With Quote
Old 02-25-2024, 07:43 PM   #4
dznf0g's Avatar
Oswego , Illinois
Yup, I went for years and never had the problem. Since coming to AZ for the winters, I've had it occur twice, and I think I need to pull it again. The screen in the valve plugs with a super fine silt. Almost looks like dissolved plumbers putty or pottery clay. And that's while running a whole house filter at the park bib.
-Rich-
Old 03-14-2024, 10:22 AM   #5
1989 34.5' Airstream 345
Avalon , New Jersey
Any suggestions?
If your camper had a built in pressure reducer, could that be getting clogged. Don't know but its a thought. Good luck. M.
Mmn46 is offline   Reply With Quote
Toilet not holding seal constantly flushing Sakura Sinks, Showers & Toilets 2 06-05-2023 07:11 PM
Water Draining from White Drain line When Flushing Toilet hoagy_007 Plumbing - Systems & Fixtures 6 06-28-2018 12:01 PM
Flushing the toilet pumps (fresh) water on the ground mstrem Plumbing - Systems & Fixtures 2 09-03-2016 08:48 PM
Black colored water when flushing toilet Mikec1231 Plumbing - Systems & Fixtures 3 06-20-2013 06:09 PM
2012 FC 25FB: Winterizing: "toilet-flushing valve"? barrettjl Winterizing, Storage, Carports & Covers 6 11-14-2012 10:47 PM
