Toilet modification in Bambi
My '01 Bambi 19 has a rear bath with angled door, a design that is used in some other AS models. 1st photo shows how the toilet is angled toward the rear, apparently to leave more leg room with the door closed. It has never worked for me, have to leave the door open and put one foot in the shower. So in the course of an interior redecorate, I decided to see if I could turn the toilet forward a bit. 2nd photo shows the flange with toilet removed. Why didn't AS use one with adjustable bolt slots? Inspection showed it is glued rather than threaded. To avoid all the work of chiseling the old flange out and also the risk of damaging the black water tank, I did this:
3rd photo shows the modified screw slots, and the tools used. I had already removed the 6 screws holding the flange to the deck so it was easy to flex the tank top and pry the flange up a bit with a putty scraper. But this could easily be done without removing the mounting screws. Just be sure to vacuum up all the dust before reassembly either way.
Drilled new holes in the desired spot with a sharp forstner bit, then cut the plastic away with a dremel saw and utility knife. Held toilet bolts with vise grips by the unthreaded tip to avoid damaging threads, heated until they melted plastic and inserted in the position shown by blue lines. Quenched with spray bottle to stop melting. 4th photo is finished install, ready for new flange gasket. Will extend the supply pipe as required with sharkbite.
