Old 09-23-2020, 07:15 PM   #1
1971 18' Caravel
Washington , Missouri
Toilet floor
I'm usually able to find what I need here with a few searches. Can anyone lead me to a thread that will help me fix a new problem in my '71 Caravelle (see attachment)?
elaboube is offline   Reply With Quote
Old 09-24-2020, 11:29 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums (or at least, to your first post).
I can't say I have seen a thread with your specific problem. Another picture showing the "big picture" layout of your bathroom might be helpful.
At a glance at your picture, though it looks like your bathroom was assembled somewhat similarly to my '73 GT. In my case, the black tank sits on the floor and has a piece of plywood sitting on top of it to firm up the upper surface. They then lay a molded ABS plastic "cover" over the tank and plywood and attach that to the wall and cabinetry. This is a marginal design in my opinion, because all of the user's weight is supported by the tank alone.
So if yours is built as described above, I would guess that the tank has been smushed (technical term) to the point that the molded plastic has pulled out of the fasteners connecting it to the cabinetry. The tank may be permanently deformed (and possibly cracked as well).
So to fix this, you may have to disassemble your bathroom fairly significantly (again, pics would help), as the tank is one of the first things to be put in place, and everything builds on top of that.
good luck!
Old 09-25-2020, 08:47 AM   #3
1971 18' Caravel
Thanks, that information is helpful.
I'm afraid it's also what I expected. I just had a hard time believing that the tank alone supported the toilet. I thought when I dug into it I might find a layer of plywood that had rotted away.
I don't have any reason to believe the tank is cracked, but it probably is smushed down an inch or so.
And yes, it looks like i'm going to have to pull much of the bathroom apart.
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Replace floor or raise toilet? chris clark Sinks, Showers & Toilets 2 02-27-2007 08:05 AM
Toilet / Bathroom floor replacement Craig Sinks, Showers & Toilets 5 05-25-2005 12:08 AM
