I have a 2007 Safari 27 FB and the toilet bowl is draining by itself. I suspect the gasket (if there is one) is allowing water to leak from the bowl into the holding tank. is there a way to repair the gasket or do i need a new toilet?
You could put some Vaseline on the gasket, they tend to dry out.otherwise the gasket can be replaced. There also may be debris stuck to the gasket, use a brush or your hand to clear it.
