01-05-2007, 02:13 PM
a.k.a. Ambassador Tim
1960 28' Ambassador
Northern
Shower wall
On my Ambassador the shower wall with the fixtures on it is part of the closet.
Originally it has a green waterproof type of wall paper on it. Ugly and needs to go!
What would be a good replacement wall covering for that?
I know, aluminum, or stainless. I was thinking of a laminate like I used for the counter tops but the stuff I have is not rated for shower use.
I thought they made laminates for shower walls, but everytime I ask the Home Depot guys they give me blank stare....
01-05-2007, 02:21 PM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
That's their natural look.
Mine has a laminate on it too but full of holes from PO's mounting things to the other side. I painted mine with the same exterior paint as the rest of the interior. Of course I would like to use the same laminate I did on the two countertops but it's discontinued. I wouldn't worry too much about it being waterproof, afterall, how long of showers will you be taking in the Ambassador? Just seal up the edges really good because the laminate itself should be waterproof.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
01-05-2007, 02:46 PM
1967 22' Safari
1960 Caravel
Edmonds
Hi Tim,
We had the same issue in our Caravel. We tore off the yucky paper, sanded down the wood wall, and coated it with primer. After that, it got a couple of coats of two-part tub epoxy. We don't anticipate taking long, luxurious showers in that wet bath, so mainly just wanted to keep the water from soaking the wood wall. Good luck!
Mel
01-05-2007, 02:58 PM
1960 28' Ambassador
Northern
That's true. Its not like it will be our daily household shower.
Maybe I could use the laminate I have. They just said it was not shower rated. I have enough to give it a try.
I wonder what makes it shower rated or not.
01-05-2007, 03:06 PM
Always Airstreaming!
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
Hi Guys- I thought the holes where there so that you could take a shower and wash your clothes at the same time! And then that would explain the missing rivits in the side wall to let the air in to dry. Sorry, but I had to do that ! Take a run over to your friendly Lowes Hardware/Lumber Big Box place. They have shower wall sheets that come in white or eggshell and are sabresaw cuttable. Pretty slick stuff to work with and you can seal the seams with white caulk [the flexible type] Danger though, use a wet paper to carefully sand the edges and not scratch the surface.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
01-05-2007, 03:55 PM
INSANITY CENTRAL
1986 32' Excella
Airstream Funeral Coach
Citrus Heights
Try some yacht paint , West Marine is where I get mine, If it's good enough for the topsides of a sailing vessel a little sprinkle in the shower should be no problem. It is pricy, but if you follow the directions and apply it with a brush it will look sprayed! honest
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
01-05-2007, 04:18 PM
1978 24' Argosy 24
Woodinville
Just saw an episode of "How's It Made" on the Discovery Channel that went through the laminate manufacturing process. It's all layered kraft paper soaked in resin. They use a different resin for the top decorative sheets that the backing and solid color tops are a little different than patterns. We used WilsonArt (a Formica brand competitor) in our bath surround at home. They preform it to the measured dimensions of your walls but I was free to choose any color/pattern from the samples. I'd call up a place that specializes in kitchen/bath remodels and ask them about the specs for different brands. I don't see why they all wouldn't be waterproof. Perhaps they have a special line of laminate with anti-microbal treatment that they call "shower rated".
Regular counter tops are bonded to perticle board. Stuff like seats in fast food restaurants are built up of numerous layers of the same substrate as they use behind the top sheet and are waterproof. They're also basicly bullet proof
Other options would be to get fiberglass panels or hack a sectional shower surround. I've been on the lookout for a sectional or better yet one piece shower stall that could be cut to fit into the rounded corner space of our rear bath unit. The idea of a thin wood veneer with wall paper was absurd. Obviously the designers back then never had to actually CLEAN the shower for themselves!
Why in the heck they ever thought putting the bath all the way in the rear was a good idea I'll never know. It would make infinitely more sense to put a bed in the most out of the way place in the trailer.
-Bernie
01-05-2007, 04:40 PM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Home Base sold a 4x8 sheet of plastic that is perfect for this. Maybe it's available elsewhere. It's not quite 1/8" thick and has a "bubble" surface on one side, the other is more smooth, but not shiny smooth. It glues up with silicone (nasty word here, I know, but in this application it's perfect). You can cut it to fit with a saber saw and then sand the edge smooth. 100% water proof and probably last forever.
I used it and a sheet of 1/2" plywood to replace the shower wall in a 60s Bambi that has been used extensively since. This was 7 years ago and it's still in great shape.
Zep
01-05-2007, 06:42 PM
1976 Argosy 24
now being enjoyed by Heath and Mary in
, Vermont
Another idea for you
Safari:
I painted that wall (and the other walls, the ceiling and the shower pan) with the POR 15 product WhiteCoat.
It seems porcelain-like in its hardness.
I will cover the biggest portion of the wall, equal to the width of the shower pan, with a sheet of clear acrylic or Lexan.
The sheet will be backed with a layer of the 3M film that signwriters use to imitate frosted glass.
I like the look of chrome, brilliant white and frosted glass together.
Sergei
01-05-2007, 08:04 PM
1960 28' Ambassador
Northern
I'm thinking some sort of laminate or panel placed over the wood closet wall would is something that I'd prefer over painting.
If my formica I used on the counter would work that would be ideal as I have it already and it would match everything else. My only concern is that Formica said it was not shower grade.
01-05-2007, 08:32 PM
INSANITY CENTRAL
1986 32' Excella
Citrus Heights
Tim; Why don't you do a little testing with your formica? Maybe spray on a coat of clear sealer or something along those lines then turn the garden hose on it for a short 6 gallons! Or coat it with flow out epoxy. Or have me fab up a carbon fiber stall for you! I like the formica approach tho give it a whirl. the other Tim
www.popasmoke.com
YETI ( 65 Quart )
01-05-2007, 10:58 PM
Hill Country
This sounds like an "FRP" (fiberglass reinforced plastic) panel. That's what I'm using, to replace the greyish-colored dull vinyl-type stuff that was on the water-exposed wood in my bathroom. Decided on the standard industrial white to brighten up the tiny area, but Lowe's carries some other products designed for bath or shower surrounds, in different colors and patterns. Talk to someone smart in their custom cabinet & countertop area, I think these are fairly new special-order products for them.... (I got my FRP panels at a wholesale specialty place, but Lowe's had some nice other options.)
Plastic laminates (Formica, Wilsonart) really DON'T hold up well to soaking.
Regards,
Lynne
01-06-2007, 04:27 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Bath Fitters
I think "bath fitters" is a national franchise. They work on homes... and should be able to do an Airstream. They actually form each surround on site. With an RV we could go to them!
Their product is a form fitted one piece shower surround that is made to cover ugly old tubs and tile.... this could be the answer to the ugly Airstream bathroom/wet bath.
I talked to a couple of vintage owners who were looking at the wet bath in my 22 and wished they could install it in their small units. Of course the radius of the ceiling curve has changed over the years and the new surround won't fit the old curve.
I STILL like my 22's wet bath better than the 25's separate shower and WC. Basically small bath = bigger closets. I only use a bath for a couple of functions and none of those take longer than 10 minutes. Cleaning a wet bath is idiot simple... spray your favorite wet clenser everywhere, HOSE IT DOWN, then wipe up the hair from the floor drain, wipe the toilet seat dry and optionally squeegee the walls. Little or no "hands on" wiping and washing of every surface, especially those yellow stains where the 3 year old nephew used the facilities!
Paula
01-06-2007, 07:47 AM
1976 Argosy 24
, Vermont
Tim:
I can’t see why Formica or Wilsonart won’t work. Like with your kitchen counter, the concern with water is at the sink and the splash back.
Similarly, if you use good moldings and caulk it should work in a limited-use shower, like in a trailer.
There are also a lot of very good specialty caulks available now.
Sergei
01-06-2007, 11:06 AM
1960 28' Ambassador
Northern
I thought this question would be slam dunk .... No problem Tim, go to isle 12....
Instead I here:
Use the formica
Don't use the formica
Use plastic
Paint it!
Call in a custom fabricator!
Maybe I should stick with the green wallpaper!
I think I'm more confused then when I asked.
01-06-2007, 11:36 AM
1976 Argosy 24
, Vermont
Information Overload
I think that you want to use Formica. Go ahead and do it. If you protect the EDGES everything should be OK.
Sergei
01-06-2007, 11:49 AM
1975 Argosy 26
1963 24' Tradewind
Seattle
formica the 2nd...
my inlaw's shower was redone with it about 8 years ago... no problem since. They did seal the seams though.
Marc
01-06-2007, 11:51 AM
INSANITY CENTRAL
1986 32' Excella
Citrus Heights
I'll third the formica!
www.popasmoke.com
YETI ( 65 Quart )
01-06-2007, 11:52 AM
1959 24' Tradewind
Phoenix
Fourth for formica. Now goet out there and do it.
FF
01-06-2007, 12:46 PM
1973 23' Safari
1977 23' Safari
Palmer Lake
Don't use the formica--brittle edges, too stiff, ugh ugh ugh...
I think I'll got to Home Depot and see if they have the plastic.
Zep
