RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-14-2021, 01:30 PM   #1
2007 25' Safari FB SE
Colchester , Connecticut
Shower drain 2007 25' Safari
I am looking for instructions on how to replace shower drain in my Airstream. The existing one has started to corrode and would like to replace before it fails. Any help with link to site or how to items would be great. Searched this site but was unable to locate instructions.
PaulZie is offline   Reply With Quote
Old 01-14-2021, 08:18 PM   #2
SandKSmith's Avatar
Scottsdale , Arizona
I can’t say I got into it that far, but I had a leak at the shower p-trap and found limited access (enough to tighten) through the bedroom heater duct on our ‘06 Safari FB SE. Best I can tell, the other option is to remove that wall.
Good luck,
Steve
SandKSmith is offline   Reply With Quote
Old 01-15-2021, 09:16 AM   #3
Thanks - I did notice same access point - and will explore more.
Old 01-15-2021, 11:08 AM   #4
Cincinnati , Ohio
Hi I have the same trailer as you do and after removing the wood panel between the bedroom and the shower you will have access to the drain pipe and trap as seen in attached photo. I have not tried to replace the drain fitting but the piping appears to be glued together so it may be a challenge.
Alumanaut is offline   Reply With Quote
Old 01-16-2021, 07:57 AM   #5
Wall removal
How did you remove the wall, is it straightforward? Also did you notice if there was a nut on the Ptrap connecting to the shower drain or was that glued in place as well? Thanks for the picture!
Old 01-16-2021, 10:46 AM   #6
Cincinnati , Ohio
The wall comes off rather easily, just remove about 8 screws and pull wire connectors from the light switch. I did not notice the shower drain connection, I was working on electrical at the time and figured I would get some photos while it was open.
Old 02-28-2021, 09:56 AM   #7
HCR
HCR's Avatar
Livingston , Full time traveler
Your post was very helpful and I thank you.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 02-28-2021, 09:57 AM   #8
HCR
HCR's Avatar
Thanks for posting as I have a slight leak with the shower drain and was having a hard time figuring out how to access it.
'06 Safari FB Water leak from Shower Drain RichHog Sinks, Showers & Toilets 0 09-01-2014 04:35 PM
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 09:42 PM
Nice 2007 airstream safari 25ft travel trailer snice 2007 airstream safari 25ft trav eBay Watch Airstreams on eBay 3 12-31-2011 03:09 PM
Nice 2007 airstream safari 25ft travel trailer snice 2007 airstream safari 25ft trav eBay Watch Airstreams on eBay 0 09-07-2011 09:50 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 05:09 PM
